Alright, someone help me figure this out.stock G56 swapped 06 cummins. So I bought the truck a little over a year ago. Truck smokes white ONLY under light to medium load between 1700 and 2500 rpm. This rpm range also seems to be low on power. Snappy bottom end pulls good after 2500 rpm (100hp single tune tuned it hp tuners) but struggles to hold speed going up a hill or something only in that rpm range. Checked turbo for leaked, dry. So I put a new set of injectors in. Still did it, took injectors back out and tested, all good. Idles smooth with no smoke. Put new tubes in the second time I put the injectors in, no change. So next I swapped fca, rail relief valve, map sensor, rail presser sensor, intake pressure sensor, all fuel and air related sensors and valves I could think of out of my 05 which runs flawlessly and made no change. I then ran some logs with hp tuners. Rail pressure desired vs actually boost all are good, I did notice the fueling on each cylinder would have the normal slight deviations and after I got into the rpm range where it was smoking they would all 0 out, not sure what to make of that. Ecm? So with almost 300k I tore the engine apart, which was in great shape, cylinders were glazed but no scuffing to speak of, valves and seats looked good etc. regardless I sent the head out and honed cylinders, fresh rings and rolled in a set of bearings and the damn thing runs exactly the same as when I bought it. Can someone help me out?
