1 - 20 of 92 Posts
I'll be calling around seeing what they charge for a rebuild. I feel like for cost, its probably more worth my time to drop in a p-pump 12v. Would the 12v work with the stock auto trans? Or should I look at a nv4500/ nv5600? The truck is also 4wd and stock. With the exception being a mopar exaughst brake.
Discussion Starter #2
It would need, engine rebuild, new injectors, new cp3. So 11-12k worth of parts, vs 3-4k for a p-pump 12v, and 1,500 for a 4wd with upgraded input nv4500.
One of my buddies is a Cummins mechanic, he said just rebuild it, more worth your time. So I'll take his word for it. Sense itll need injectors, should I get stockers or something over?
I plan to build this truck, auto will need attention, valve body upgrades are good till 400hp. What would I need to do transmission wise for 500+?
What about fuel side for 500+?
And turbo wise. Compounds or a 66?
On call 24/7
Buddy just had a shop rebuild his 07 5.9 and it cost him right at $11,000.
That seems like a pretty good price.
.. New injectors 30% over tips, 10% stroked CP3, tubes about $4,400
.. Engine kit $1,100
.. Nice Turbo upgrade $2,500
.. Guessing 40 hours Remove, Rebuild, Install $4,000
Damn, I'm $1,000 over budget
On call 24/7
They didn’t touch injectors, pump or turbo.
I know itll be 5k or so just for engine, 2500 for injectors, 800 for cp3. I know right around 8k to get it running.
Discussion Starter #9
Ill throw another option your way. Get rid of the 5.9 and get a used 6.7. You will get a lot more power out of the gate. The extra torque is noticeably different.
Can I drop in a 6.7? Do I need any extra controllers, or wiring stuff?
Depends whats wrong. I bought my 01 with a bad case of blow by . Turns out the previous owned ignored the injectors and a few ring packs shattered.
When I pulled it apart surprisingly the bores really werent scored. I sent my block to a machine shop and they where able to clean it up with a hone only .
I did the rebuild myself. All new bearings gaskets rings redid the head. I was able to go through the whole engine for a 1000$ in parts and machine the shop honing my bores and the piston pins for the rods.
I would take the engine apart and if you have the time and go from there . If you have the time do it yourself It doesnt have to cost much to rebuild a engine . You just have to take your time and pay attention to tolerances.
Discussion Starter #11
All 6 cylinders are tore up pretty bad.
2 pistons are eaten threw. Didnt get down to the bottom of the engine yet.
All will depend on whether block, head and crank are rebuildable.
Good 3rd Gen 5.9 blocks and cranks are getting as rare as panties on one of Trump's wives or women in pubic and as expensive as all his attorneys/law firms paying off the girls and divorce bills.
What are your motor precision assembly skills?
Good local experience Cummins diesel engine machinist locally?
Machine shop sleeving of a 5.9 parent bore block gets real expensive real quick
Ouch , your screwed sounds like . I would still keep it common rail though. The ppump was the only good thing about the 12v . I own both a 12v and 24 and I wouldnt trade my 24v for the world.
You can always PM ( or email is my screen name @gmail.com ) me if you need advice . Ive been in your position with a few engines.
It May be cheaper to get a running engine or a short block with higher miles and do a refresh. Bore hone gaskets bearings redo head.
Discussion Starter #14
I have a VP truck, love it. Sounds way better then the 06. I'm not mechanic, I've done things when needed, like a head gasket, shops wanted 3k to do it. Just the Labor cost. So I did it myself.
That's why I'm leaning towards a mechanical engine, or as mentioned a 6.7. A buddy of mine has a Cummins out of a peterbuilt and and 6 speed Eaton. No idea what size it is, he said he'll look again.
it is pretty easy. Pull your 5.9 out. Place it next to your new 6.7. Swap over your ecm, harness, exhaust manifold and turbo, take out your injectors and put 03-04 spray pattern tips on them, put it all together and put the engine back in.
Discussion Starter #17
This was when I just pulled out my 5.9 and put it next to my new 6.7
Will any 6.7 work? Do I need to look for specific years?
Pretty much any 6.7 would work but if you get the 13 and newer, they had better emissions stuff on them and tend to have less issues. If you go for the 13 or newer, you have to change over the idler pulley and mount to the old style and a couple small things. My engine was a 2016 with literally 1 mile on the odometer. I tore it apart and put all the upgrade parts in it.
Discussion Starter #19
Sweet man, I'll see what's up when I get around to it, however id delete it right away.
1 - 20 of 92 Posts
