I have 05 2500 i have a smarty programmer that puts out up to 210 hp a afe cold air intake 5 in exhaust and afe downpipe and a built tranny i bought this truck from a friend and it runs good but not like i think it should from a dead stop its very slow but from 70mph stomp it will fly is it something leaking turbo wise or wastegate im new to this world of a cummins i just think it should run better its like im losing boost from a takeoff id appreciate any input
Gears?? Tires size??
Is it a stock turbo or aftermarket? Is your current tune adding fuel+timing, or just fuel? Do you have a boost gauge on it?
33x1250x20 it has rail pressure on tune with additinal timing people have told me it could be the wastegate but idk if you hold the brake and boost it up its very slow going but if your rolling at a good speed it will run great its a stock turbo could it be that its not getting enough fuel i just dont understand it with what i have done to it i figured it would run amazing in any situation i havent installed gauges
Put your tm at 3 or 4 on the smarty thats where the off the line power is
· Diesel sniffer
And please use punctuation in your posts.
