1 - 12 of 12 Posts
I just got a cummins and i was wondering do you control quadzilla adrenaline, smarty, and a edge juice with attitude with one module.how Do you do that. And how big of hp injector can i use on a stock clutch.
The Quad, Smarty, Edge are all seperate units and you control each one through its own box. The Quad and Edge are both touch screen units. The Smarty you plug it in and set it up then unplug and drive. I did read where the Smarty POD can be controlled by Edge but only the POD and now the actual software. As far as injectors, I have a Smarty on my 6spd and it alone (only other mods are CAI and exhaust) will slip the clutch if turned up.
Stock clutch won't hold much power like he ^ said. Mine slips with preditor and powerpuck
Ok thank you. What stage clutch should i use. Some of my buddy have a south bend clutch in there truck but which one should i use if im going to use a 5in straight pipe from turbo back, a smarty, edge juice. And a quadzilla adrenaline. And 150 hp injectors
That's depends all on if you tow or not, I don't tow much so I ordered the valair 600hp clutch
If you tow I know a lot of people seem to like the dual disc clutches but, I'm sure somebody else will chime in with more useful information
That I don't know I'm looking for some as well, you can have your stock nozzles honed out that's what I may en up doing, extrude hone does them
I wouldn't update the injectors until you get a larger turbo and update the CP3 pump. A tuner is plenty enough for the stock turbo and pump. The clutch on the NV5600 is pretty stout if it hasn't been abused. Can easily handle 100+ HP if you don't get crazy with it.
Your questions can be easily read if you do a search. There are already tons of threads on all that. Read a little bud
:agree2:
Spend afew days just reading around and searching. If you still have questions after that, then by all means ask away. There are 6755988905895 threads about which clutch, where to buy and so on.
1 - 12 of 12 Posts
