1 - 11 of 11 Posts
Hey everyone. I have a 04.5 Cummins. The main brake line for the rear got a hole in it. When I went to take the hard line off the rubber line that connects to the rear brake distribution block I broke the fitting. The question I have is.... is there any place I can buy the distribution block without it being from a stealership OEM part number I believe is5212118ad. Auto zone and a couple others tell me its a dealer only part and they want 298.00 plus tax for. Small piece of metal and a rubber line that comes off it. Any idea where I can buy and a part number would be great
You are talking about the rubber line that comes down from the frame and mounts to the axle. Then from there the hard lines go to each rear wheel? You can buy that at Napa or any parts store. Maybe take a pick so we know exactly what you are talking about
Technically, it is a 04, LOL. I go to the Speed Shop and get AN stuff, -3 line with a Napa three way tee should fix you up.
MOLON LABE
My block broke right off the axel tube. Is that what happened to you?
Sent from AutoGuide.com App
Vendor
Technically, it is more of an '05 then '04. :doh:
Agreed 'tho get the parts at a Napa.
1 - 11 of 11 Posts
