The 47re stopped early 2003. IIRC. 48re took over in 2003.5are there any differences between the 03 and 04 47re's and the previous 02/earlier 47re's (input shaft, valve body, etc.)?
The pump is different, Overdrive with clutches, Valve body passages, Planet Gear sets, Front Ring Gear set's there are a lot off changes from the 47RE to the 48RE and the R = rear wheel drive :thumbsupjust internals. 4(four speed) 7( 7 on scale to 8 of power handling) R( dont remember lol) E(electronic or something)
8 is obviously better but no much different.
btw, i'm missing the power of big injectors/comp/clutch. i bet i'm making a whole 180hp at the rear wheels!:woot::rof
All that means is bigger gains!:thumbsup Where in NH are you, by the by?btw, i'm missing the power of big injectors/comp/clutch. i bet i'm making a whole 180hp at the rear wheels!:woot::rof
Transgo instruction cover a range of years irregardless of what was actually made in that year. The instructions for the 05 48RE are also for a V10 trans and that motor was out of production for 2 years by then.i had hoped it's the 48re, but Transgo's installation instructions say about the vin 6/C being what they are.
my truck came from cali before being shipped to mass where i bought it off a dealer. no one talks about the 235hp motor and it's features...hence why i'm asking here...
rottenchester. i'm always on the NETDP...i use CF when i'm getting into the more technical stuff though.All that means is bigger gains!:thumbsup Where in NH are you, by the by?
As your is an 04, its almost a given its a 48RE, Cali truck or not. AFAIK, the 47RE went out of production mid MY03. Every thing after that was a 48RE.
What you may have is the early VB and that will make a difference in how you install the kit. The instructions should tell you how to identify thye VB's.
Yes, the earlier VB's used the same kit as the 47's. Its actually a pretty decent setup and it is tried and true. I would just go with it and not worry about swapping VB's. You still have the bigger parts and all the updates to the main trans itself. I would go with what you have.it says that the earlier valve bodies...to use the TFOD kit (which is the 47re kit). so they put in the older style valve body in the first production of the 48re? if so, could this be changed out with a 48re valve body?
I got a 04 California 235.It has a 48re with 3.73 and 10.5 rear end.i had hoped it's the 48re, but Transgo's installation instructions say about the vin 6/C being what they are.
yeah, the blue one? i'm trying to find his vids on youtube...I got a 04 California 235.It has a 48re with 3.73 and 10.5 rear end.
Well from what I seen and know,their is a guy out in California that made 1289 HP with his 03 California 235.And he told me to get the 235 because its more reliable at higher power,though I have no clue :lol3:.
