1 - 4 of 4 Posts
Man... I am 50:50 excited/frustrated. I got a lot of work done on my engine tonight but I have run into a road block. I do not have a pic of how the engine harness is supposed to run. I am pretty sure I have it mostly right. One question is, does the cam and crank position sensor wires go behind the cp3... And if so can you squeeze them in or do they have to be run before the pump is in? Thanks for your help!
Figured out the routing issue. Now I have 2 plugs and a ground I cannot place. The black plug and the ground are on the same "leg". The grey plug with the orange boot seems to go towards the back of the engine but I am not sure. Any help is appreciated.
1 - 4 of 4 Posts
