1 - 4 of 4 Posts
Guy looking to get some tow mirrors. Off the newer dodges. I dont like none of the strap on mirrors. like some of the flip out ones
Well they fit. on a 01 dodge
Second.
Well any of the new dodge 2500 2wd rear ends bolt up to my 01 leaf springs. i dont want to down size tire size so id like to swop in 3.73 gears. And have found the hole rear ends cheaper then i can do a gear swop.
Any ideas!!!!
Discussion Starter #2
Come on no one has done any of these swops.:banghead:
The rear end swap is not a direct swap. The spring mounts and shock mounts are different. I am not sure if a 16" wheel would work either due to the brake rotor diamater, I know 16's won't fit on the front.
The tow mirrors are also different where they mount to the door. There is an aftermarket version of the mirror and there were factory non power tow mirrors for the 01 and 02 trucks that are a direct bolt on.
Thanks i didnt even think about the rims not clearing.
If im going to spend good money on mirrors they better be eletric. That why im looking at the newer one.
i dont need heat. but some of the places i go i need to be about to move them around while back up.
1 - 4 of 4 Posts
