1 - 2 of 2 Posts
hello i have my 03 3500 was running edge ez (great MPG) then bought a PMT (i just like it ok) it did a very good job and i have been searching if i can stack the two.. i got the normal 5" exhaust , intake, gauges bla bla bla any know if they will work... i hooked it up and it seems to be running fine did a slow roll into first to see if i would hear it bog or anything and ended up breaking tires loose in 3rd and getting some rail pop.. it idles a little louder even when i have it on the stock setting on my pmt. just looking for some input and no i dont run scary larry just extreme (for now).. thanks.
Tech Specialist
The PMT for the 03's advances timing and extends duration only. The EZ increases pressure only. They should stack fine together. The only problem you may run in to would be draining the rail, which it sounds like you have already experienced.
1 - 2 of 2 Posts
