1 - 12 of 12 Posts
I blew a power steering hose , cleaned up the mess replaced the hose, driving down the road, truck revs up to about 3grand and dies the truck will not start. I have replaced the fuel filter, fuel pressure regulator and new batteries still no start , took to dodge dealer cause I had a p2509 my mechanic buddy said computer maybe needed to be flashed , dodge mechanic said computer is good and needed to do a fuel test , lift pump good, injector pump good but I only had 149 psi at rail he checked the fuel pressure relief valve it was bypassing like crazy, he says I needed a new one put new one on fuel pressure at rail is no 500 psi but still no start , now he is testing the injectors.....anyone else been through this any ideas.....
Rail pressure failed to build up for ECM to fire injectors.
Already replaced fuel filter,FCA and PRV.
The only left to replace would be injectors/tube and CP3.
Reactions: gcon4418
Does it start with a wiff of ether? and then will it run fine? or will it not keep running? if it starts with ether, id say injectors are returning too much, or injector feed tubes, check for wetness by injector lines, tightin all feed tube nuts, cap off injectors individually or pull them out and get checked
Contaminated fuel? Id maybe lean towards that, should be able to tell if the injectors are pulsing if rail pressure is high enough. if it doesnt continue to run after a little ether then injcetors arent getting fuel or for some reason not pulsing.
I had one come in with contaminated fuel, was getting rail pressure but no start, it plugged up the rail, and obviously injectors
update on my truck for those who may be interested.......well it is no longer at the dealership. Now it is at xtreme diesel they pulled the injectors and found 5 clogged and one beautifully streaming. they are thinking contaminated fuel I just hope once the injectors are replaced the truck will fire and run and I hope the cp3 is fine ....that's all I know now I will post updates as I find them out.
Discussion Starter · #10 ·
cp3 is good they cleaned fuel tank and found the screen on the pick up tube was torn and allowing sediment or whatever you want to call it through which he thinks clogged the injectors anyways new fuel pump, new injectors and labor $3182 buckaroos..........he said its running and will run.......
· TECH SPECIALIST
Any water in fuel? Any corrosion in injectors, feed tubes or CP3?
A quality water separator/fuel filter in the canister would have stopped all that krap. Baldwin PF7977 5 micron in the canister asap
Lots of the junke out there on the market lets 10 micron thru which will kill injectors and has NO water separating capability.
Discussion Starter · #12 ·
i will be getting one thank you.
1 - 12 of 12 Posts
