Just purchased an 03 3500 2wd NV5600 with 420k miles on it. Probably not the original engine by the way it looks. The previous owner fired the parts cannon at trying to fix a no start issue. The no start issue has been solved but the truck sputters at WOT between 2250 and 2800 RPMS.
List of new parts includes
New ECM (still on stock tuning for now)
New in tank sending unit/lift pump (oreilys)
New stock size injectors and tubes (oreilys)
New fuel filter
The truck runs flawlessly until you get high up in the RPM’s at wide open throttle. Rail pressure moves between 17k and 22k at WOT. I’m watching data on a Edge monitor and it does not have a PID for desired rail pressure. Should I start looking at CP3? Could it be the pressure relief valve in the rail?Looking for some input before I start throwing unnecessary money at this thing.
New fuel filter
