1 - 18 of 18 Posts
I just installed an afe mega cannon on my truck and when i started it up it threw a cel..after i drove it about 5 minutes i stopped and checked to see what code it threw..it was a 0102..i searched around and it said P0102-mass Air Flow Sensor "a" Circuit Low..anybody else have this problem or know how to fix it? Thanks
2008 6.7L 1 ton dually 4 door 4x4 automatic patriot blue, front replacement, b&w hitch, bully steps, 7" screen with 2 kicker cvt 10's
had a problem like that after i did mine ... turned it off never had it again
mine also, maybe the computer detected something and threw the code. after 5 driving cycles should go away
ok..thanks to both of yall..if it persists i will let you know..
how much louder is the turbo whistle?
The turbo is quite a bit louder and the code went away
so that whistle is pretty loud now?
yes the turbo is very audible with the mega cannon...especially with a tbe. I really like te sound!
Once i get my refund check, ill be ordering the code free kit from BADP, and the afe.
Love the whistle.:peelout
does anybody have an issue with the overhead saying service filter after installing the afe. I have the afe with dryfilter and recently after less then 1000 miles keeps telling me it needs serviced.
my mega cannon works great without any problems and with the silencer ring removed this thing singssss!!! sounds great... exhaust break sounds really awesome too with the tbe real loud and deep
Discussion Starter #14
how do you remove the silencer ring on the 6.7?? i had a 5.9 and i removed it, but i thought the 6.7 looked different..
Im with you roo roo1986 I did it on my other 5.9's but from what I hear you have to drill it out on the 6.7's? Im not about that for not getting any real gain from it.
Discussion Starter #16
yeah same here..im not real confident in myself to be drilling on my turbo, especially if it doesnt help any
na its not too bad once u get it all out. the hardest part is drilling straight. take the alluminum side of the turbo housing completly off and tap and drill... real simple just be really careful when u take it off and put it back on to not damage ur turbo vanes. but ya once you drill ( not all the way through, just enought for the ring to come out) turn the housing over and there are 3 ribs inside the silincer ring... use a screw driver and tap on them till it comes loose. just dont tap on the same rib too long, hot one pretty good and rotate. you'll feel it come loose
and when i put mine back in, i didnt use and allen screws or anything. just it being pressed in was enough. took it off the other day again and it hadent budged at all. so i think just pressing it back in is fine
1 - 18 of 18 Posts
