1 - 4 of 4 Posts
My internet is super slow so it takes a half hour each time i search so im sorry for not searching first but if you can help me out at all that would be great.
The fuel pressure dropped to 1 psi while i was driving "check gauges" light came on and my tranny temp rose to about 30 or 40 degrees higher then normal operating temp. so i pulled off and cut it fast. i smelled some rubber burning and it smelled like a wire around the tranny but i couldnt find where. when i went to go start it it just went click. tried again and click. so i figured my alternator went out for some reason which would be why i lost power to my fuel pump and why it wouldnt start. i pulled these codes.
0177
0460
0622
1693
1765-i dont have a lockup switch
0460 fuel level sensor circuit malf., 1693 code detected, 177 fuel compensation circuit. po622 alternator not charging
P1765-SWITCHED BATTERY
POSSIBLE CAUSES
INTERMITTENT WIRING & CONNECTORS
2C PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
4C PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
L/R PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
OD PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
UD PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
TCM- SWITCHED BATTERY
From an '01 service manual.
P0177 Water In Fuel.
Excess water found in fuel by water-in-fuel sensor.
P0460 Fuel Level Unit No Change Over Miles.
Fuel level sending unit voltage does not change for more
than 40 miles.
P0622 Generator Field Not Switching Properly.
An open or shorted condition detected in the generator
field control circuit.
P1693, companion code, both PCM & ECM are aware.
P1765 Trans 12 Volt Supply Relay CTRL Circuit.
An open or shorted condition is detected in the
Transmission Relay control circuit. This relay supplies
power to the TCC (torque converter clutch).
All help gratefully accepted.
okay the water in fuel light turned on a couple weeks ago after washing the undercarriage but turned off shortly after and the fried wire would make sense for the shorted wires. thank you very much i really appreciate it
1 - 4 of 4 Posts
