OK, a few months back I replaced my lift pump because the truck would occasionally sputter or miss at idle and only 1 or 2 times it stumbled when pulling out from a stop. The pump was still working but I could not hear it when I cycled the key so I just replaced it. I also installed a fuel pressure light, comes on at under 5psi, and replaced the filter becuase the light would flutter when I would get above 1000RPM. That filter worked, no low pressure light, for about 20 miles before the light started to flutter again. The light mfg stated that the light coming on was normal for a stock motor & lift pump so I lived with it. In the past 2 weeks the sputtering has gotten worse and even stalled on me. I will sit at idle and stare at the pressure light and it does not flutter when the engine stumbles. I have talked to 2 mechanics and one is saying water in the fuel being pushed through the filter and the other is saying algea. I replaced the fuel filter on Sat and the light was out for about 3 miles before it started fluttering again. Monday morning it sputtered and stalled on me in the driveway and then ran like a champ the rest of the day.
Today I stopped and got PS Biocide, I do use PS with every fill up, and was told by the parts guy to use dry gas becuase it sounds like water to him. He has some that says it is for diesel but it still contains alcohol and I was always told to never use that in a deisel engine. He claims that the truckers swear by it.
Everything seems to have gone down hill for me since the ULSD change over.
With everything that I've read on here I have a injection pump going bad to an air leak in the system. I don't think it's an air leak becuase I can click the key for the heater and the pressure will hold above 5psi for about 8-10 seconds after the pump stops running.
I really don't wish this problem on anyone but I'm hoping someone else has had this issue and can help me out. At this point I'm about to drive it off a cliff.
Sorry this was so long but I'm really at a loss with this. Any help that anyone can provide would be greatly appericiated. Thanks in advance.
