1 - 16 of 16 Posts
Okay guys I got a code for a camshaft position sensor and won't go away. When I start my truck it runs real rough for about 10 secs then my RPMs drop to zero and my idle levels out and it runs great, but no RPM gauge? And so a little back story, when I first bought the truck guy said it had a bad ecm, and was tuck in limp mode? So he gave me an extra ecm and a pcm and said he pulled them from a junk yard. So I slapped the new ecm he gave me in it and it drove fine. Minus the RPM gauge. So I took it in and got the ecm flashed. But now my problem is when I plug a nice fanny scanner in it, it tells shows me a different vin and says my truck is a 99? My truck is a 01. 1/01 to be exact. So long story short, my question is do you think the place I took it to didn't really flash it? Or if they did, did they not program new ecm to my vin?? And I replaced camshaft sensor twice! Which was a pain!!! So do you think some how some way the ecm is not registered the cam sensor?? Any help would be awesome. Thanks
Discussion Starter · #2 ·
Okay guys wanted to add a quick side note. So the scanner is saying my truck is a 99 which I'm thinking is the ECM, the engine tag says 8/12/00 and my truck door tag says it's 1/01. Maybe this will help narrow down my problem. Thanks
A ‘99 ECM won’t work on an ‘01 truck/engine. Pretty straightforward and not really much else to it. This “flash” you had done wouldn’t fix the problem. Internal circuitry is different. Get the right ECM.
· Vendor
Do you have the part numbers on the ECM & PCM to help point you in the right direction? Are u able to read the part numbers off a scanner? Most likely have the wrong computers set up for different functions and not programmed correctly.
First figure out what you have. You can not do anything until you do. First loook atthe engine near the starter and see if there is a crank shaft sensor beside the starter. If so the engine has been replaced with a 99, Check the part number on the ECM and report back to tell if it is a 99 or 01. If you have a 99 engine you must have a 99 ECM, harness and the crank sensor, If an 01 engine it will have a different ECM, harness and no crank sensor. Both engines have a Cam sensor but they are differnet.
Sorry just seen your replies. Okay so the tag on my engine says says o8/12/2000. My truck is a 01/2001. But when I plug scanner in my truck and it says model year 1999? But I did swap ecm when I got the truck. The guy gave me a extra ecm and a pcm and I only swapped ecm. Then I took it down to get flashed. There is no crank shaft position sensor near the starter. It only has a cam. And I've already swapped cam sensor twice with no avail. The rpm will work for a few seconds while started. The drops to zero? Im doing head gasket now so I pulled whole wire harness off and went through the whole thing with a fine comb soldering and heat shrinking any thing that look damaged. I'm waiting on head gasket now so won't be able to fire it up for a week or so. But after doing research I found schematic for 99 and 01 and the same color wires for the crank on the 99 are the same color wires for the 01 cmp sensor. I think pins 3,4,17 on my 50 pin connector. So I'm wondering if my ecm is a 99 and my 01 wire harness is the problem?
That is easy, what is the part number on the ecm?
.....336 is an ecm for a 98.5/99, and looks for a crankshaft position sensor, and I do not know that they can be simply reflashed to an 01. Even if they are, they would have to be in good serviceable not defective condition in the first place. ..336 does not work on 01/02
Discussion Starter · #13 ·
My truck runs and drives minus overdrive and the cam situation. Is there any way I can swap around a couple pinouts? Say pins 17, and 9? The cmp signal is on 9 on the 99 and on 17 on the 01. Or will that ruin my ecm? I know dumb question I'm just tight on cash because I'm doing head gasket and studs right now. Plus the wire loom I bought when I pulled wire harness$$ . Tha KS
Dont start screwing with wiring you know nothing about, Get the right harness if you have the wrong year harness.. If you have the worng ECM you need to buy the right ECM(correct PN) Use old one as core. You can get luck for $300 or not for 1200.
I do not know about ruin the VP but definitely will not run right if at all. Low lift pump pressure or high AC from alt are the main things that can damage the VP or other electronics.
1 - 16 of 16 Posts
