Clutch Questions HELP!!! - Dodge Cummins Diesel Forum
Valair Inc.
post #1 of 2 (permalink) Old 10-04-2017, 09:13 AM Thread Starter
nocerus03's Avatar
Many, many years ago, i purchased a used but new dual disc clutch from a member here and installed it in my '05 Ram 3500. As of lately, when i have the clutch pedal pressed in, it sounds like the trans is ready to explode. There is a very loud, destructive sounding rattle coming from the trans, that when the clutch is released (no pressure on the pedal) goes away. The clutch still feels good, it does not slip on acceleration. Any thoughts what i could have going on? Is it possible that the throw out bearing has gone bad? Broken pressure plate? I really dont want to have to go and spend the money on a new clutch if its just a $35 bearing, however i am entertaining the idea of doing so. Any idea on what cost would be for a clutch that would fit my application?
The truck is my daily driver. Info is in my sig.
2005 QCSB 3500 LARAMIE SPORT TRX-4 / 6 SPEED / 5" RSD TURBO BACK KIT / AFE STAGE 2 INTAKE / SMARTY SO6-POD / SUPER B SPECIAL / SOUTH BEND DUAL DISK 3250 / AUTOMETER BOOST PYRO RAIL PRESSURE / 35" PRO COMP XTREME AT / EAGLE ALLOY SERIES 050 18" RIMS
nocerus03 is offline
post #2 of 2 (permalink) Old 10-04-2017, 10:18 AM
StealthDiesel's Avatar
Your sig says Southbend dual disk clutch.
From your post, it sounds like the rubber dampers in the flywheel and center plate have failed.
Pull the clutch to examine, take pics and then call Southbend.
2004.5 Dodge SB QC 2500 2wd Cummins 600/6spd manual/3.73 LSD
ATS 3K/5K Twin turbos. DDP 50HP tips, F1 valve springs, ARP headstuds.
SBC Dual disk 3250. Smarty. Glacier Diesel intake plate, air horn, fuel & filter system.
MBRP S.S. muffler. BD short shifter. Brakesmart tow controller.
BD exhaust brake. Pullrite 24k Superglide.
StealthDiesel is offline
