RV tips!! - Dodge Cummins Diesel Forum
Towing & Hauling Discussion of Towing & Hauling Habits
 8Likes
post #1 of 527 (permalink) Old 09-27-2013, 02:05 PM Thread Starter
RACE KTM
NC4stroker's Avatar
RV tips!!
It would be nice to have a helpful RV tips thread. These are just some quick tips I've done on my camper today.
Please add your helpful tips!!
I use a small syringe to add Clorox to our fresh tank. You can check out tables to get your Clorox at a certain PPM if you want to.
The lower trim pieces on my RV were loose and I found one on my driveway as soon as we got the 5er home. I took them off and put a thin bead of silicone on the trim pieces. I then put them back on and wiped off the excess silicone!
You can see the small trim pieces on either side of the reflector in the pic.
We put a clip like the orange one in the pic, on our breakaway cable for ease of attachment to the 5th wheel hitch.
16 Mega DRW, Aisin, 4:10s, Fuel wheels, Nitto Mts, Promaxx LEDs.
2015 Jeep GC SRT.
2014 Jeep GC Overland Diesel
1986 Jeep CJ-7 Last of the real Jeeps!!
2012 Shelby GT500...Borla Axle backs, TVS blower, JLT 127mm intake, Ford Racing 65mm TB, AFCO dual-fan HE, and Forgestar CF-5 wheels.
NC4stroker is offline
The Following 3 Users Say Thank You to NC4stroker For This Useful Post:
camperman (09-27-2013), Hermes1 (04-08-2015), Mega10Cab (09-27-2013)
post #2 of 527 (permalink) Old 09-27-2013, 07:15 PM
Mega10Cab's Avatar
Thanks. This should be made sticky. Hoping sealing the deal on our first 5r tomorrow morning. 2010 Sandpiper 38' triple slide.
2010 2500 4x4 Big Horn, Smarty, MP8, Deleted, 5" Flo Pro, GDP Open Breather, Silencer Ring MIA, leveled, bilstein, Timbrens, 20s/33s, Carli Low-mount, Tint, Laramie Flares.
Mega10Cab is offline
post #3 of 527 (permalink) Old 09-27-2013, 07:42 PM
Go Packers
camperman's Avatar
I would like to add a couple of thoughts if I may. Before leaving, check torque on trailer wheels. If on a longer trip, check periodically during trip. Also check torque on 5er hitch nuts & bolts. Our 5er has grease zerks on the shackles, don't forget them. This is probably old hat to most, but worth re-mentioning. The most important thing is this, have a great rving experience. Getting there is 1/2 the fun.
2012 SLT 3500, CCLB, HO, SRW 4x2, 4.10s, 68RFE, Mineral Grey, Pacbrake air bags, Fumoto oil valve, Cat/Cummins Dual Filter kit, Edge CTS Monitor.
camperman is offline
The Following 3 Users Say Thank You to camperman For This Useful Post:
09W3500 (05-07-2014), NC4stroker (09-27-2013), pbgmag (09-27-2013)
post #4 of 527 (permalink) Old 09-27-2013, 08:20 PM
CRASH9116's Avatar
I'm in the process of deciding if I like RV'g so I purchased a 95 model Jayco pop-up that appears brand new. Once I install my spare axle from my dually conversion under it I think I will be in heaven. I agree, the RV/Camper folks need to have their own space.
06 megacab 3500 2wd, dually conversion, Smarty S0-6, Airdog 165, Suncoast VB, and more gauges than your neighbors Honda Civic
CRASH9116 is offline
post #5 of 527 (permalink) Old 09-27-2013, 08:51 PM
I like the caribiner idea, thanks for that!
The only recent tip I can offer so far is tires...got some Bridgestone Duravis R250's installed on my fiver and could not be happier. Full steel cap, couldn't wait to ditch the crappy ST trailer tires.
pronstar is offline
The Following User Says Thank You to pronstar For This Useful Post:
post #6 of 527 (permalink) Old 09-27-2013, 09:41 PM
wixthedog's Avatar
Buy a box of nitrile gloves and USE THEM when you are handling the gray/black water discharge duties.
Buy the drill adapter for the screw jacks and make sure your drill is charged.
2016 2500 CC 4x4 6.7 68RFE 3.42 - Silver
'15 Crew Crab 1500 = '14 Mega 2500 = '14 Crew Cab 3500 = '13 Crew Cab 3500 = '07 Quad Cab 2500 = '03 Quad Cab 1500
wixthedog is offline
The Following 3 Users Say Thank You to wixthedog For This Useful Post:
Cthulhu (09-29-2013), NC4stroker (09-27-2013), Viper67 (05-07-2014)
post #7 of 527 (permalink) Old 09-27-2013, 10:16 PM Thread Starter
RACE KTM
NC4stroker's Avatar
I use the blue nitrile gloves for the messy diesel pumps too!!!
2015 Jeep GC SRT.
post #8 of 527 (permalink) Old 09-27-2013, 10:21 PM Thread Starter
RACE KTM
NC4stroker's Avatar
Camperman, after getting our new 5er home, I rechecked the lug torques, and believe it or not, several on each tire were not at the proper torque! Then I rolled the camper forward so the tires rotated 180 degrees, and torqued again. Great advice!
2015 Jeep GC SRT.
The Following User Says Thank You to NC4stroker For This Useful Post:
camperman (09-28-2013)
post #9 of 527 (permalink) Old 09-28-2013, 09:23 AM
haulin-rv's Avatar
One step further on the breakaway cable, you can get these at at some rv dealers and most Farm and Fleet or Tractor Supply. And ebay and Amazon of course. Oh and DON'T just attach to your fifth wheel, a breakaway should be attached to the trick itself. In the commercial world that can get you an out of service violation from an officer.
2016 Loaded Mega Laramie 2500
haulin-rv is offline
The Following 7 Users Say Thank You to haulin-rv For This Useful Post:
09W3500 (10-14-2014), gotdiesel04 (10-18-2013), NC4stroker (09-28-2013), pbgmag (10-01-2013), RVT (03-06-2015), Scott91370 (10-20-2013), vreihen (09-28-2013)
post #10 of 527 (permalink) Old 09-28-2013, 09:33 AM Thread Starter
RACE KTM
NC4stroker's Avatar
If you have a new RV, or before taking your first trip on which you'll need heat, I would advise running your RV heating system to burn off the initial "junk" in the heating system.
Because......last night at 2AM the propane-fired central heat came on, and 10 seconds later the smoke detector did it's thing!!!! So there we were doing the fire detector hokey pokey, fanning the thing, and turning on our exhaust fans!!!
B20vtec and A55 like this.
2015 Jeep GC SRT.
The Following 4 Users Say Thank You to NC4stroker For This Useful Post:
4gsfarm (03-03-2014), A55 (01-07-2017), CANYONBIKER (02-28-2014), Stagman (03-31-2015)
post #11 of 527 (permalink) Old 09-28-2013, 09:47 AM
Snofarmer's Avatar
Grease those wheel bearings....
Jack up each wheel and cheek for any play
Snofarmer is offline
The Following User Says Thank You to Snofarmer For This Useful Post:
post #12 of 527 (permalink) Old 09-28-2013, 11:32 AM
Slats Extend's Avatar
After latching your Fiver to the hitch, connect the pig tail, raise the landing gear enough to put all the weight of the trailer on the truck and have the landing gear just off the ground.
Get back in your truck, put it in gear while holding the trailer brakes locked with the brake controller. Put just a little throttle in to check that things are properly engaged.
This check would save the side rails of your truck bed in the event that something was not quit right with the hitch or locking mechanism.
2016 3500 Laramie Limited, AISIN, 3.73,RVK 3600. Titan 55 gal fuel tank, BD TSB
2012 Ram 3500 CCLB Laramie 4x4 DRW 68RFE 4.10 ,
BUYBACK.
2005 Ram 3500 CCLB Laramie Dually,auto 4x4 3.73 Traded
2001 Ram 2500 QCSB SLT+ Auto 4x4 3.54 SOLD
1992 W250 Getrag, SOLD
Slats Extend is offline
The Following 7 Users Say Thank You to Slats Extend For This Useful Post:
camperman (09-28-2013), CANYONBIKER (02-28-2014), fourtangi (06-21-2014), Mono06cummin (02-07-2014), NC4stroker (09-28-2013), RVT (03-06-2015), Scuba0331 (04-03-2016)
