IBC with EOH at stoplights - Dodge Cummins Diesel Forum
Towing & Hauling Discussion of Towing & Hauling Habits
 1Likes
  • 1 Post By -lenny-
post #1 of 4 (permalink) Old 07-26-2019, 11:29 PM Thread Starter
Loving my new 2018 Ram 2500!. Towed the 9-10K boat for the first time this week and she did great! Only one gripe, when stopped at a red light, the brake controller keeps the EOH pump working. At the end of the day the brakes were hot! On my old truck I had an aftermarket controller that could sense when the truck was stopped and would shut the EOH pump off. I'm worried that this may burn the pump up over time or cause premature wear on the components. Is there a setting that I'm missing or a way around this?
thanks!
Alexlikestacos is offline
post #2 of 4 (permalink) Old 07-28-2019, 12:41 AM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
Are you running light EOH or heavy EOH?
2018 RAM 4500 Chassis Tradesman Crew Cab 60 C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Continental HDRs, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 150,076 miles and 2,654 hours as of July 12, 2019 (Average Miles Per Hour = 56.5)
gsbrockman is offline
post #3 of 4 (permalink) Old 07-28-2019, 06:53 AM Thread Starter
I’ve tried both and it does the same thing. Boat and trailer weigh
About 9-10k depending on fuel and gear.
post #4 of 4 (permalink) Old 08-13-2019, 09:42 PM
Administrator
-lenny-'s Avatar
So you are saying that your old brake controller would stop applying the trailer brakes because you were stopped? I have not run into that before on any braking system. I have EOH brakes on my 5th wheel, which is a little bit north of 18k loaded. As you mention when you apply the brakes while stopped you can hear the pump running, but without that there would be no braking... I think the longest day I have had towing was around 8 hours since the install, and while I have not checked the oil reservoir temp the hubs were fine. Maybe your gain is too high? I have mine set at 4.5 FWIW.
gsbrockman likes this.
Boyd
2015 6.7L Mega Cab
3500 4x4 AS69RC 4:10 DRW Laramie
B&W/AMP Research/Transfer Flow/Bakflip/Amsoil
Heavy, Slow, and Reliable
Password problems, username change, thread issues? PM any staff member or report posts anonymously! Always happy to help.
-lenny- is offline
