Size comparison question - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By Broncowilly
post #1 of 9 (permalink) Old 11-09-2016, 11:12 PM Thread Starter
Broncowilly's Avatar
Tire size comparison question
Fellas, I have stock LT265 70R 17 E range tires on my truck. It is pretty much stock except I put a two and a half inch leveling kit on the front end. What problems, if any, would I run into going to a LT285 70R 17 E?
TIA
Bill H.
2003 Ram 2500 4X4 Quad Cab Smarty SO6 395HP tune, Edge CTS, 4” Diamond Eye exhaust
Psalm 83:18 2 Timothy 3:1-5
Broncowilly is offline
post #2 of 9 (permalink) Old 11-09-2016, 11:31 PM
purplepuller's Avatar
No Problems at all. Put 2 inch leveling kit on mine with 285s. Ran for 4yrs. then went to 305s. Still no problems.
06 2500 Laramie 4x4 QCSB SRW AM Pyro, Rail Pressure & Trans Temp, Isspro Oil Pressure 2 "leveling kit 5100 bilsteins 08.5 steering AFE Stage 2 Pro MBRP 4 inch Catless 305/70/17 Ridge Grapplers. Trans rebuilt, Banks Techni-Cooler IC , MSD Kit with Cat Filter
purplepuller is offline
post #3 of 9 (permalink) Old 11-09-2016, 11:33 PM
KATOOM's Avatar
Thread title may mislead some members into thinking this is an off topic discussion.....
As for 265 compared to 285. They're very close in size and wont make much difference. But that said, all tire sizes will vary from tire manufacture to manufacture. It would be best to look up the specific tire of choice and see what their dimensional specs tell you.
KATOOM is offline
post #4 of 9 (permalink) Old 11-09-2016, 11:40 PM Thread Starter
Sorry for that, I fixed the title.
Thanks for the information.
ETA: well I thought I fixed the title
KATOOM likes this.
Bill H.
post #5 of 9 (permalink) Old 11-09-2016, 11:51 PM
ganzey's Avatar
265 is roughly a 31" tire, the 285's are about 33". either way, they should fit a stock truck
'02 2500 ECLB, 4x4, NV5600 tst comp/ts mvp, SO VP44, FASS 150, 7x.012's, ARP Studs, 64.5/68/14, Kenny's triple disc, 110# springs. 298k miles.
'02 RCLB, rwd, auto. bone stock
ganzey is offline
The Following User Says Thank You to ganzey For This Useful Post:
Broncowilly (11-10-2016)
post #6 of 9 (permalink) Old 12-02-2016, 06:21 PM
You can go to a 285/75/17 and it looks perfect... no issues at all...
if you want to see some picts... let me know. I can take a few more.
I've got the 988 springs. about the same as a 2" lift.
About 33.85 tall
11.61 wide
03 3500 QC/LB SRW auto - LT285/75 Nitto Dura's - TRE trans w/triple - B&M 10280 - 4770 Filter Head -Carter P4070 - (FASS Platinum on shelf) - S06 PoD - BMS 50s - Donaldson M101167 - 08.5 Steering - 988 Springs - 5100's - CTS2
gasjr4wd is offline
post #7 of 9 (permalink) Old 12-17-2016, 02:33 PM
I'm looking at getting 2012 dodge 18" rims and 285/70/18 AT3s. I would like to know how much different the 2012 18" inch rims are from my 2006 17" inch rims. I'm concerned about offsets and back spacing and if they will rub on suspension components. Will the fit be much different. I'm looking into 2 " inch level or 3" inch suspension.
2006 CCLB 2500,silver, stock , 373,
Bluejoe is offline
post #8 of 9 (permalink) Old 12-18-2016, 11:35 AM
I feel like some of this can be miss leading ... specially if you dont know metric tire sizes are based off the rim ... so same numbers like 285/70/18 will not be the same size as a 285/70/17
06 4WD QCSB, 48re full billet goerend, 140k miles, 5" str8 , smarty touch + udc pro from innovative, exergy 100hp injectors , halmiton 103 springs + push rods , arp 625's , compounded 362sxe s475
shanesnofear is offline
post #9 of 9 (permalink) Old 12-18-2016, 02:18 PM
What I'm looking to find out is the offset and backspace of my original 17" time and also backspace and offset if the 2012 rims. I would like to know this before I purchase the 2012 18"inch rims. The cooper AT3 285/18 I like are just shy of 35"inch tall. I would go install a 2" inch leveling kit and I don't want the tires to rub because backspace is not correct.
Bluejoe is offline
