https://www.toyotires.com/media/1492/tsd-12-015_tips_tire_rim_slip_vibration_complain.pdf
Excerpts:
"Toyo recently completed a test of four tire brands, including Toyo, revealing that tire slip on wheels is a major cause of vibration leading to customer complaints after mounting new tires and wheels.
"The main cause of tire/wheel slip is excessive use of tire lubricant (shown on the right) on the tire beads and rim. Excessive lubricant reduces friction between the tire bead and the wheel, allowing the tire to slip within hours of mounting...
"Toyo believes that tire/rim slip from over- lubrication and its affect on balance is one of the major causes of customer complaints for ride vibration on new tire and wheel assemblies."
This info is not new, but posting, betting many of you aren't aware; If this has been posted before, I apologize; I can't properly search messages with my work's firewall!
Excerpts:
