6BT Powered 1987 Landcruiser - Dodge Cummins Diesel Forum
post #1 of 1 (permalink) Old 09-18-2015, 02:03 PM Thread Starter
I have up for sale a project truck of mine, I hate to let it go but due to some changes in life it will get more use from someone else.
Here is a basic description of the truck:
1987 FJ60 Body
Rust Repaired
Quaterpanels Chopped
Front Fenders Modified
Rear Storage panels / Sleeping Platform
1990 FJ62 Frame
Custom Front Bumper
Cummins Engine Cradle
NP205 Cradle
Shock Crossmember
SOA with 52" Hybrid Spring Pack up front
3/4 Ton 63" Chevy Rear Springs
Bilstein 7100 Shocks Front and Rear
1992 Cummins 6BT
60mm WH1C turbo housing upgrade
M&H M2 Fuel Pin
M&H Timing spacer
3200 RPM Spring
PYRO, BOOST, H20 TEMP Gauges
Frozenboost Intercooler
Rear Freeze Plug Upgrade
New Saginaw Power Steering Pump
Hydroboost Brakes
New Alternator
Dual Batteries
Grid Heater Delete
Block Heater
???? Clark 280VO Medium Duty TransMission 2WD
Modified Getrag Bellhousing
4 Button Clutch
1.5" 10 Spline Input
1480 Output
???? Dodge NP205
Twin Stick Conversion
1410 - 1410 Front Driveshaft
1480 - 1410 Midshaft
1350 CV - 1410 Double Cardan Rear Driveshaft
1992 Dodge D250 Dana 60 Front Axle
Spartan Locker
Hy-steer Arms and new 1 TON TREs
New Calipers and Pads
Roughstuff HD Diff Cover
pre-87 14 Bolt Rear
13 Bolt Crane-Hi-Clearance Cover
Shaved
Disc Brake Conversion
New 3/4 Ton Calipers, Pads, Discs
Grizzly Locker
37" Military Tires
That is what I came up with, there is probably even more that I have forgotten. Also included with the truck are all of the fluids, gasket sets, extra parts and also a Warn 8274 Winch.
I know I will not get back what I have put into it, however the experience of building it was worth every second.
I am asking $12,000 OBO
For Pictures here is my build thread, or PM me with requests to be sent to your email.
Stevo's 6BT60 Build Thread | IH8MUD Forum
Engine Bay:
With the old 43" TSLs:
As it sits now:
See attached photos
Stevojones is offline
