Budget Friendly 5.9L & 6.7L Stock Long Blocks - Dodge Cummins Diesel Forum
Industrial Injection Diesel Performance Industrial Injection Diesel Performance
post #1 of 1 (permalink) Old 06-29-2018, 03:07 PM Thread Starter
Supporting Vendors
Industrial Injection's Avatar
Industrial Injection 5.9L & 6.7L Dodge Cummins Common Rail 24 Valve Stock Long Block Engines
The Industrial Injection Stock Cummins Long Block was designed for those who are looking for the most reliable & affordable stock replacement engine. We use the highest quality parts and machining processes in every engine build, guaranteeing you the utmost reliability and precision to have the longest running engine on the road.
Stock Cummins Engine Specs:
-Sim Tested Short Block
-Factory OE Mahle Pistons
-Stock Cummins Crank
-Stock Cummins Rods
-Stock Cummins Camshaft
-New Oil Pump & Oil Cooler
-New Oil Pickup Tube
-Stock Oil Pan
Stock Cummins Cylinder Head Specs:
-Reconditioned Head
-New Diamond Honed Valve Guides
-New Stainless Steel Valves
-Cummins OEM head gasket
-Milled & Surfaced Head
-Factory Head Bolts
-New Valve Springs
*Does not come with valve cover
*Does not come with water pump
Budget Beater: 9.36 @ 148 MPH
Industrial Injection is offline
