Lighting problem - Dodge Cummins Diesel Forum
Electrical & Wiring A place to discuss Electrical & Wiring issues.
post #1 of 2 (permalink) Old 11-14-2018, 07:16 AM Thread Starter
Lighting problem
So..I know it doesn’t have the Cummins but I’m assuming it’s mostly the same as far as wiring. 1995 Ram 1500 5.9 gasser...problem is as follows..headlights/running lights and turn signals including hazards all work fine up front...however in the rear I have no running lights or brake lights and both turn signals flash regardless of which signal is on...but the reverse lights work...seems like a grounding issue?..not sure where they’re supposed to be grounded though..also the third brake light also does not work..thoughts???
The Brat is offline
post #2 of 2 (permalink) Old 11-15-2018, 07:58 AM Thread Starter
So I found a ground on drivers fender well that looked chewed..replaced it and hit brake lights to work(except the third one)..but all other problems remain..and is that the headlight relay on the passenger fender well?..
The Brat is offline
