Aux Switch Ground Questions - Dodge Cummins Diesel Forum
Electrical & Wiring A place to discuss Electrical & Wiring issues.
post #1 of 4 (permalink) Old 06-12-2018, 05:43 AM Thread Starter
IchLiebeBier's Avatar
Hi all,
I've been searching for this, but I must not be typing in the correct search terms.
Three questions:
1. Can you ground all 5 aux switches to the "Chassis Ground BK" plug?
2. If so, what is the load limit (amps) for the ground wire?
3. I have my self-installed front camera on one of the switches. If I put in a light bar and ground them together, would it likely cause interference with the camera? Should I isolate them?
Electrical science is not my forte. Hats off to electricians.
Thanks.
'18 Granite Laramie 2500 CC 4X4 CTD / Air Susp / Anti Spin / Wheel-to-Wheel Sidesteps / Husky Guards / Dee Zee Assist / Gator FX /AVS Aeroskin II / I-P Switches
IchLiebeBier is offline
post #2 of 4 (permalink) Old 06-12-2018, 11:53 AM
badtoejam's Avatar
Why not just ground one of the negative terminals of each accessory to its mounting location? Only one wire to run to the aux switch.
2016 Ram 3500 Laramie CC LWB DRW
6.7L Aisin 4:10
Amp Research Powersteps
badtoejam is offline
post #3 of 4 (permalink) Old 06-12-2018, 05:53 PM Thread Starter
Well I assumed the ground wire hookup helped provide some protection to the truck electronics. In my old truck splicing into the wires threw the TPMS code. I was trying to avoid CELs.
post #4 of 4 (permalink) Old 06-15-2018, 08:11 AM
I built a small buss bar and attached it directly to the neg battery terminal.
Jhenderson is offline
