4 button AUX wiring questions - Dodge Cummins Diesel Forum
Electrical & Wiring A place to discuss Electrical & Wiring issues.
post #1 of 3 (permalink) Old 03-22-2018, 09:02 PM Thread Starter
Hey guys I have a 2010 6.7 I run a bale deck on it so I have a hydraulic pump that runs that. Originally I just had the basic rocker switch that ran it with the 3 wires, I was always hitting my knee on it and such. So I decided to pick up this 4 button OEM deal that fits in the slot where is usually says ram under your Jake brakes. So anyways I found a wiring diagram for it somewhere on here and hooked it up. I’m getting nothing, no lights no pump turnin on nothing but when I go back I click the 12v and the pump wires together behind the box it kicks my pump on. Did I wire it wrong? Do I have a bad 4 button box? Or is it not big enough to handle it? This is the diagram I used
Ol'02 cummins is offline
post #2 of 3 (permalink) Old 03-28-2018, 01:07 PM
You might have a bad switch box. I would use an ohm meter and check the switches. Also I would use relays to take the load off the switches.
redneck733 is offline
post #3 of 3 (permalink) Old 05-27-2018, 06:02 PM
You have the switch wired to a relay and the relay wired to the pump motor? Cant wire the switch directly to pump motor
2008 QC 3500 4x4 68rfe 3.73's 6.7
PMT;S&B;Custom turbo elbow;EGR unplugged;5" TBE;Quad Boost Fooler;3.5" intake elbow;Black H2's W/ 35-12.50-17 MT ATZ's
daveyclimber is online now
