Weigh Safe Hitch - Dodge Cummins Diesel Forum
post #1 of 1 (permalink) Old 03-26-2019, 11:13 AM Thread Starter
Clayton @ Dude's Diesel Performance
Dude_57's Avatar
Weigh Safe Hitch
Looking for that one of a kind hitch? Wondering how you could possibly know if your loaded correctly and safely? Well take a look!
CLICK HERE to check it out! Also follow the link below!
https://www.dudesdieselperformance.c...egory=34320023
The Weigh Safe Drop Hitch is the one and only trailer hitch with a built-in scale that signals you to adjust your load before you hit the road, resulting in a much safer and enjoyable towing experience. Before this ball mount, gauging your trailer’s tongue weight was a hassle. You had to rely on inefficient bathroom scales, make a trip to the weigh station, or purchase a separate tongue weight scale. But with the Weigh Safe’s built-in scale, measuring your tongue weight is as easy as coupling your trailer to your ball mount. Simply hook-up your trailer to the Weigh Safe ball mount just as you would any other ball mount. The weight of your trailer will push down on the hitch ball, which in turn pushes down on an internal hydraulic piston that sits on a bed of oil. When the piston drops into the oil, the pressure reading is sent out to the scale.
What is tongue weight and why is it important?
Tongue weight (TW) refers to the weight that the fully loaded trailer exerts downward on the hitch ball of the tow vehicle. Tongue weight is typically 10 percent – and should not exceed 15 percent – of your gross trailer weight. For example, a 10,000-lb trailer should have a tongue weight between 1,000 lbs and 1,500 lbs. You can adjust the tongue weight of your trailer by removing or adding cargo, or redistributing the load on the trailer. The tongue weight should not exceed the capacity of your tow vehicle, your hitch, or any of your towing components.
Simply put, too little tongue weight can cause trailer sway and too much tongue weight can cause the tow vehicle to perform poorly. You may have difficulty steering, gaining traction, or braking when driving a setup that has too much weight pushing down on the rear of the vehicle. Ultimately, towing with an improper tongue weight can cause you to lose control of your vehicle or cause your trailer to separate from the vehicle.
Matthew 6:9-13, 2 Corinthians 5:20
See what we are up to on:
Dude_57 is offline
Similar Threads
Aluminum Hitch Stuck on Truck! 20:04:05 General Diesel Discussion 0 07-23-2016 01:21 PM
Anderson Ultimate 5th Wheel Hitch review MN246 Towing & Hauling 10 07-18-2016 07:35 AM
need answers to hitch question stump-puller Towing & Hauling 5 12-17-2015 06:16 PM
Multi-functional hitch mount steps carid CARiD.com 0 11-16-2015 09:16 AM
Husky Fifth Wheel Hitch Issues Kitty 3500 HD Towing & Hauling 6 04-18-2012 02:50 PM
