Hand Shaker 1/4 & 1/8 Mile Times In Here!!! - Page 89 - Dodge Cummins Diesel Forum
Cummins Racing Discussion Pertaining to Cummins Racing On the Street or On The Track
 4Likes
post #1057 of 1061 (permalink) Old 09-26-2018, 12:41 AM Thread Starter
Bangin' through the gears
Sandaholic's Avatar
Is the handshaker all but dead?
05' QCLB 4x4 NV5600,
,6" Atlas leafs & Thuren Coils
<<<Link to pics
647/1180 [email protected] 7700lb race weight
Sandaholic is offline
post #1058 of 1061 (permalink) Old 09-26-2018, 10:30 AM
3 footin' through life
Broaner's Avatar
iTrader Score: 11 reviews
Seems the whole forum is all but dead. Too many people too busy on the failbook to give a hoot. Failbook sucks for documenting info but it still seems to be popular due to ease of use.
I am planning to hit the track in spring with the truck. Hoping to touch 11's and then I'm done caring about 1/4 mile.
Sandaholic likes this.
'05.5 6.7 Shotpeened NV5600 - 12.6 @ 111.6 - 994 HP & 1630 lbs/ft
150%'s, LBZ/Arson pumps, MHP +1mm, ZZFab, Wagler Rods, 69/73/1.0 & s482
1350 Frontshaft, TruTrac, 315's, 64" T-Bars,TGC 1/2"+, Carli BJ's, '08.5
Street Triple, 103#/Extreme Pushrods, 625's
Broaner is offline
The Following User Says Thank You to Broaner For This Useful Post:
WillM (10-01-2018)
post #1059 of 1061 (permalink) Old 10-20-2018, 12:51 AM Thread Starter
Sandaholic's Avatar
Name - E.T. & Trap, trans, 4wd or 2wd, weight, tire size, gear ratio, hp & tq dyno'd or estimated, clutch, engine(12v, PPump, VP 5.9 or 6.7 CR)
1/4 MILE
SRT6.7 - [email protected], gorilla56, 4x4 xxxx,305/50/20, 3.73, 1300hp+, triple disc gorilla, 6.7 CR
gecoveyc - GOOSE - [email protected], NV5600, 4x4, 7200?, xxx/xx/17, 3.73s, HP/TQ?, Valair Triple Disc, 6.7 CR
lvramcummins - [email protected], NV5600, 4x4, 7650lbs, 285/70/17, 3.73's, 787HP, Valair Triple Disc, 5.9CR
Dodge05CR - [email protected], G56, 4X4, 7100lbs, 285/65/18, 3.73, 700hp/1200tq, SBDD3600 6 button, 5.9 CR
gecoveyc - MAVERICK - [email protected], NV5600, 4x4, 7400lbs, 33/13.5/18, xxx/xxxx, Valair Street Triple Disk, 5.9 CR
1SLO_CR - [email protected], G56, 4x4, 7100lbs, 325/60/18 Toyo A/T, 3.73, 838/1691, SBC 3600DD Diaphram solid hub, 5.9 CR
Broaner - [email protected], Cryo NV5600, 4x4, 7500lbs, 315/70/17, 3.73, 811/1583, Street Triple 3200 Diaphragm Plate, 5.9 CR
95civic2005 - [email protected], G56, 4x4, 8100lbs, 33/12.50/18, 4.10, 765/1245, SB 3850 DD, 5.9 CR
ramtd02 - [email protected], G56, 4x4, 7520, 35's, ?, 707/1255, Spec Twin Disc
boostn06Cummins - [email protected], G56, 4x4, 7100lbs, 315/70/17, 3.73, 436/1083, SBDD3600
Sandaholic - [email protected], NV5600, 4x4, 7700lbs, 305/60/17, 3.73's, 647/1180, Spec DD, 5.9 CR
DMX4SNX - [email protected], nv4500, 4x4, 7395lbs, 33x12.5R16.5 baja at, 3:73,446/968, ?
smoke machine - [email protected], g56, 4x4, 7800, 35/12.5/20, 3.73, ??????, valair tripledisc, 5.9 CR
Cummin_Get_Some - [email protected], G56, 4x4, ?, ?, ?, ?, ?
RobertP - [email protected], G56, 4x4, 7350lbs, 33" AT's, ?, 650/?, SBC DD, 5.9 CR
Lostnwalmart - [email protected], nv4500, 4x4, 6000 ish, 305/60 r18's, 605/1357, Valair dd 4k pressure plate
coopercummins67 - [email protected], nv5600, 4x4, 8100lbs., bfg265's, ?, ?, ?
rtofflemire - [email protected], NV4500?, 4x4, ?, 265/75/16, ?, est. 600+, Power Parts Engineering solid hub dd, PPump 12v
MfolsomblueD - [email protected], NV5600, 4x4, ?, 33", 3.73, 543.9/1080, Valair cer/kev
Grapevine [email protected], nv5600 , 4x4, 7350#, 295/70/17, 3.55's, 482-802, valair ceramic DD street, VP44
smkin6spd - [email protected], NV5600, 4x4, 7300lbs., 33's, 3.55, 727/1440, SBC 3850 12CB rigid hub
Justin Price - [email protected], NV4500, 2wd dually, 6700lbs, 265/75/16, 3.55, 517/979, ?
brpcummins03 - [email protected], g56, 4wd, ?, 265's, 3.73, ?, stock ?
RAN '07 - [email protected], G56, 4x4, 7115lbs, nitto 235/60/18, ?, ?, SBC 3600
TTR 21 - [email protected], NV5600, 4x4, 7800lbs, 37/13.5/20, 4.10, 681/1200+, SB 3600 DD, 5.9 CR
mzcummins - [email protected], G56, 4x4, 7500lbs, 33/20's, 3.73, 504/1180, SBC 3600DD
MR4WLR - [email protected], NV5600, 4x4, 8200lbs, 35's, 3.73, ?, Haisley Street Puller, 5.9 CR
bgreen776 - [email protected], N5600, 4X4, 8500lbs (Dually), 235/80-17, 4.10, 667/1326, SB3250DD SFI Ceramic w/ bronze inlay
Mattlosch - [email protected], G56, 4x4, 7600lbs, 37/12.5/17, 3.73, Dyno'd 477/1092, Valair 360d0DD, 5.9 CR
ckassen - [email protected], NV5600, 2wd, 6450lbs, 285/70/16, 3.55, ?, single disk clutch
hightimes2 - [email protected], NV4500, 4x4, ?, 245/65/16's, 3.55, I would guess around 550hp, w/valair DD
ATP-Mike - 14.1 @ 106.8mph, G56, 4x4, 7xxxlbs, 275/65/18 Toyo A/T, 3.73 630-650HP, SBC OFE, 5.9 CR
EnduringAtlas - [email protected], G56, 4wd, 7400lbs, 285/70-17, 3.73, 580/valair 3800lb, 5.9CR
mudn_1 - 14.3 @104mph, nv5600, 4x4, 7300, 315/75r16, 3.55, ???/???, SB 3600 6cb, VP?
Atvracn08 - [email protected], NV4500, 4x4, ?, 265/70/16, 3.55, 481hp/1023tq, Valair Cer/Kev
dvt4u - [email protected], NV5600, 4x4, ?, 35's?, ?, ?, SBC 3600DD, VP
High Voltage - [email protected], G56, 4x4, 7800lbs?, 34's?, 3.42, 500/950?, Stock clutch?, 6.7
Motoracer057- 14.450 @ 94.72, G56, 4wd, 7600lb, 35/12.50/18, ?4.10s?, 447hp & 976tq, SBC 3250
Volcom18 - [email protected], G56, 4x4, 7855lbs, 325/65r18, 3.73's, 460/900, SBC 3600dd
K5Cruz - [email protected], G56, 4x4, 7480lbs, 33/12.50/18, 3.73, 458/941, Valair 12.25 Iron DD
jmd025 - [email protected], NV4500, 2wd, 6700, stock tires, 3.55, ?, Valair Kev/Cer Single
No23 - [email protected], NV4500, 4wd, 6400lbs, ?, ?, 568/1200, single disc
Maniac - [email protected], nv4500, 4x4, ?, 325/60/18, 3.55, ?, Valair DD
Sticker89- [email protected], G56, 4x4, 19.5 tires, 3.42 8300lbs, Valair DD
gschwepp - [email protected], g56, 4x4, 7400lbs with me in it, 285/70/17, 3.73s, 467/894, sbdd
v8440 - 14.67 at 98.00, nv4500, 2wd, 7000 with me, stock tire size, 3.54's, 450 hp and 920 ft/lbs dynod, sb 3850 dd
THE HAMMER - [email protected], NV5600, 4x4, 7600lbs, 35X12.5X17, 3.73, 580hp/1198tq, SBC DD4200
Leyerly1 - [email protected], G56, 4x4, 7800lbs, 35x20, ?, ?, SB DD 3600
shroyer702 - [email protected], nv5600, 4x4, ?, 285/65r18, 3.73, ?, Haisley Machine Street Drag
Futrao - 15.056 @ 108.14, G56, 4x4, 7600, 35's, 3.73, 715/1266, DD3600 Ceramic, 5.9 CR
dennhop - [email protected], NV4500, 4x4, ?, 315/75/16, 3.55, 506/1016, SBC CON OFE
jmd025 - [email protected], NV4500, 2wd, 6700, 32/12 M&H, 3.55, ?, Valair Kev/Cer Single
[email protected],G56,4x4,7600,235/75/17,3.73,hp+tq???,sbc ofe
Electric_Cowboy - [email protected], NV5600, 4x4, 7900lbs, 315/75/16, 3.55, 279/711, SBC CON OFE, VP
04.5bigred - [email protected], nv5600, 4x4, 7850lbs, 35/12.5/17, 3.73, ?, stock clutch CR
Ganzey - 16.082 @ 88.32, NV5600, 4x4, 7300, 315/70/17, 3.55, 424/1067, Kenny's Triple, 24v VP
Matt 12 - [email protected], NV4500,4x4, ?, 285/75/16, 3.55, ?, Valair 3850 DD
9812v5spd - [email protected], nv4500, 4x4(ran in 2HI), 7800lbs, 395/75/16, 3.55, ?, south bend con ofe, PPump 12v
1/8 MILE
lvramcummins - [email protected], NV5600, 4x4, 7650lbs, 305/55/20, 3.73's, 787HP, Valair Triple Disc, 5.9CR
Dodge05CR - [email protected], G56, 4X4, 7100lbs, 285/65/18, 3.73, 700hp/1200tq, SBDD3600 6 button, CR
Jff24Gordn - [email protected], NV4500, 4x4, est. 6500lbs, 285/75R16 Pro Comp AT, 3.54, est. 700-800hp, Haisley Drag Twin, PPump 12v?
1SLO_CR - [email protected], G56, 4x4, 7100lbs, 325/60/18 Toyo A/T, 3.73, 838/1691, SBC 3600DD solid hub, CR
Boostn06Cummins - [email protected], G56, 4x4, 7100lbs?, 315/70/17, 3.73, 4336/1083, 3600DD, 5.9 CR
Broaner - [email protected], Cryo NV5600, 4x4, 7500lbs, 315/70/17, 3.73, (811/1583), Street Triple 3200 Diaphragm Plate, 5.9 CR
MfolsomblueD - [email protected]?, NV5600, 4x4, ?, 33", 3.73, 543.9/1080, Valair cer/kev, CR?
Sandaholic - [email protected] NV5600, 4x4, 7700lbs, 305/60/17, 3.73's, 647/1180, Spec DD, 5.9 CR
gecoveyc - [email protected], NV5600, 4x4, 8200lbs, 33/13.5/18, ?, ?, SBC sprung-hub 3600DD, 5.9 CR
operator62 - [email protected], g56, 4x4, 8000lbs?, 255/80/17, 3.73, 550/1100 Est, South Bend DD
rtofflemire - [email protected], NV4500?, 4x4, ?, 265/75/16, ?, est. 600+, Power Parts Engineering solid hub dd, PPump 12v?
Boostn06Cummins - [email protected], G56, 4x4, 7100lbs?, 315/70/17, 3.73, 436/1083, 3600DD, 5.9 CR
Woosley - [email protected], G56, 4x4, 7450lbs, 285 75r17, 3.73, 574/1248, South Bend 3600, 5.9 CR
8UPRACIN - [email protected], NV5600, 4X4, 7980, 305/50R20, 3.54, 591/1275, SB3600DD, VP?
RAN '07 - [email protected], G56, 4x4, 7115lbs, nitto 235/60/18, ?, ?, SBC 3600, 5.9 CR
Tyler irvin - [email protected], NV5600, 4x4, ?, 35/12.5/20, ?, 553/1025?, valair sd?
Mitchellfried - 8.78 @ 83.5, G56, 4WD, 8111, 34", 3.73, 846/1456, Valair Triple, 5.9
Cnp22 - 8.822 @ 76.96, getrag, 2wd, ?, 29.5/10.5-15s, 3.55, estimated 400hp, valair single disk
yoda - [email protected], G56, 4x4, 7452lbs, hankook 305/55/20, ?, ?, SBC 3250
Atvracn08 - [email protected], NV4500, 4x4, ?, 305/70/16, 3.55, 481hp/1023tq, Valair Cer/Kev
Motoracer057- 9.263 @ 76.34, G56, 4wd, 7600lb, 35/12.50/18, ?4.10s?, 447hp & 976tq, SBC 3250
gschwepp - [email protected] g56, 4x4, 7400lbs with me in it, 285/70/17, 3.73s, 467/894, sbdd
taterbob01- [email protected], NV5600,4x4, ?, 315/75/16, 3.55, ? ?, valair ceramic single
Farm_Kid_Diesel - [email protected], nv4500, 4x4(ran in 2HI), 7500lbs, 285/75/16, 3.55, 328HP/964, ceramic single disk Valair
pipeliner_dodge - [email protected], nv5600, 4wd, ?,265/70/17, 4.10, ?/?, sb3600dd
Ganzey - 10.687 @ 70.11, NV5600, 4x4, 7300, 315/70/17, 3.55, 424/1067, Kenny's Triple, 24v VP
<<<Link to pics
post #1060 of 1061 (permalink) Old 07-22-2019, 02:59 AM Thread Starter
Sandaholic's Avatar
Wink
Well I can't remember if they archive threads here or not, but I might as well bump this one. If things work out well I'm hoping to be in a new place with a shop and hopefully a project truck not long after. Mmmm some standard cab goodness........delicious. And also, lets throw some MAGA up in here for good measure
<<<Link to pics
The Following User Says Thank You to Sandaholic For This Useful Post:
Broaner (Yesterday)
post #1061 of 1061 (permalink) Old 08-21-2019, 09:29 PM
humphrey169's Avatar
Watch “Untitled” on Vimeo: https://vimeo.com/335624865?ref=em-share
Got me a srt8
94 f350 p pump cummins 67/75 stage 5 suncoast 48re pcs controller dually
humphrey169 is offline
