Introduction - Toyota Land Cruiser 6BT/NV4500 Swap "The Overland Tractor" - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By will van
post #1 of 6 (permalink) Old 05-07-2019, 01:39 PM Thread Starter
Hey guys! I'm new to the forum and I wanted to introduce my build.
I have a 1993 Toyota FZJ80 Land Cruiser that I am swapping a Cummins 5.9 6BT and NV4500 5-speed into. It should make a helluva Land Cruiser when I'm done.
The donor motor is a 1996 12-valve with the P-Pump out of a 2WD automatic Dodge w/ 240k miles.
https://youtu.be/SguehRH_opQ
The NV4500 a 1997 with the "old-style" top cover plate.
First order of business is to get the engine on a proper engine stand and start de-greasing and teardown.
Also, first dumb question - What is this for?
98whitelightnin likes this.
will van is offline
post #2 of 6 (permalink) Old 05-07-2019, 04:55 PM
9297oldram's Avatar
Nice build, I moved you to the Conversion section.
That circled hole is the access to the torque converter bolts.
Are you completely tearing it down, if so why? You should tab the KDP, R&R the front and rear seals, tappet cover and adjust the valves.
Most people just leave the top cover off when they do a Conversion with the engine, it's a Cummins engine not a Dodge engine.
9297oldram is offline
post #3 of 6 (permalink) Old 05-07-2019, 07:35 PM Thread Starter
Thanks for moving me to the correct section!
No, not a complete teardown. Similar to what you suggested - KDP, seals, tappet covers, new water pump, valve adjustments, etc.
I may go ahead and swap to ARP head studs, rebuild the turbo, and upgrade the exhaust manifold. Plus gauges (EGT, boost, water temp).
It was leaking oil pretty bad, so the motor is filthy. I need to figure out where the oil is coming from, but it looks like the timing housing/gear case. I need to pull the alternator, A/C compressor, and compressor bracket anyway. So might as well give it a thorough cleaning and repaint too. Do any vendors offer a good seal kit?
I'm for sure going to pull the Dodge vanity cover from the Cummins valve covers.
Thanks for the info on the torque converter access hole. I assume there is no difference between the manual and automatic flywheel housings?
will van is offline
post #4 of 6 (permalink) Old 05-07-2019, 07:46 PM
9297oldram's Avatar
I used Fel Pro gaskets and seals and haven't had any issues.
post #5 of 6 (permalink) Old 01-13-2020, 01:58 AM
CJGuy's Avatar
Rear structure will be the same for autos and stick.
May I ask why youíre doing a 12 valve into that cruiser? What engine is in it now? Only reason I ask is Iíve had 12 valves all my life and just a few weeks ago picked up an HDJ81 with the 1HDT. Itís certainly no Cummins but itís about as dead simple as one and definitely moves the cruiser around with power to spare
Sent from my iPad using Tapatalk
It's a First Gen, and it does First Gen stuff. It doesn't give a damn, it just does it
CJGuy is offline
post #6 of 6 (permalink) Old 01-24-2020, 03:36 AM
Hi there)
dream-builder is offline
Similar Threads
Another successful 48RE to G56 6 speed swap MTMike 3rd Gen. Powertrain 72 05-08-2018 04:19 PM
Swap Cummins 5.9 24v 2001 on Toyota Land Cuiser AndresToycummins 98.5-02 Powertrain 24 04-13-2018 09:51 AM
Swap used truck cap from Ford GM Toyota? MikeRodrig27 98.5-02 Non-Powertrain 0 08-19-2013 12:13 AM
