1963 Dodge Crewcab 2wd Conversion - Dodge Cummins Diesel Forum
 7Likes
post #1 of 34 (permalink) Old 01-01-2019, 11:53 AM Thread Starter
slicknapier's Avatar
So here we go with my conversion. A lot of my build will be piggybacking on Ramx4 because I really like what hes doing.
My 63 is my daily driver. It currently has a 2000 Magnum 5.2. Is been great, but Im looking for a little chassis/power upgrade.
Plan for my truck is a lot of rust repair and putting my truck on a 93 2wd 5.9 Cummins 5 speed extended cab long bed frame. The 93 frame has a 3 longer wheelbase. The plan as of now is to 4 link and airbag the rear. This will allow me to move the axle forward and achieve my desired wheelbase. I will be running a York AC compressor for my air system.
So far the front end has been rebuilt and I have swapped the cab onto the 93 Frame.
ID:	837061   Click image for larger version
ID:	837063   Click image for larger version
ID:	837065   Click image for larger version
ID:	837067   Click image for larger version
thrashingcows likes this.
1963 Dodge Crewcab 2wd Cummins in progress
1993 W250
slicknapier is offline
post #2 of 34 (permalink) Old 01-01-2019, 11:58 AM
Going to be a cool ride
Sent from my SM-N910P using Tapatalk
7091ram is offline
post #3 of 34 (permalink) Old 01-08-2019, 09:30 PM Thread Starter
Little more progress. Got the brake master cylinder and clutch master cylinder mounted. I also got the pedals squared away. I ending up using the 93 clutch arm and pedal. I cut the pedal off the arm and moved it up 3/4. Then, I cut the pedal off my factory 63 brake arm and the pedal off the 93 arm. I welded the 93 pedal onto the 63 arm. I moved it down 3/4 lower then the factory pedal. Now I have matching pedals.
ID:	837739   Click image for larger version
ID:	837747   Click image for larger version
1993 W250
post #4 of 34 (permalink) Old 01-08-2019, 10:12 PM
9297oldram's Avatar
You'd probably be happier with a Hydroboost brake system then you could also delete the vacuum pump.
9297oldram is offline
post #5 of 34 (permalink) Old 01-08-2019, 10:46 PM Thread Starter
I have been thinking about it. Would you recommend the newer dodge one or a Chevy style one?
1993 W250
post #6 of 34 (permalink) Old 01-08-2019, 10:48 PM
9297oldram's Avatar
I used the one from my old 97 Dodge Cummins on my Blazer.
post #7 of 34 (permalink) Old 01-08-2019, 11:40 PM Thread Starter
Just did a bunch of reading and it looks like a good idea. Vacuum pump delete looks like its a little pricey..
1993 W250
post #8 of 34 (permalink) Old 01-09-2019, 01:04 AM
thrashingcows's Avatar
No need to delete the vacuum pump....just plug the end and run on, not going to hurt anything if it's building vacuum and it's not going anywhere. But I agree Hydroboost is the way to go....I did this on my 1st Gen crewcab build and is one of the best upgrades I have done to make the truck just that much better, and safer to drive.
1984/93 Dodge Crewcab, W350, 1 Ton SRW, long box, 370K Km's, hydroboost, 366 spring, fuel pin to deep side, 14cm housing, Piston LP, PS IC, Isspro Boost, Pyro and tach, NV4500, 29 spline NP205, 3.54's.
thrashingcows is offline
post #9 of 34 (permalink) Old 01-09-2019, 10:25 AM Thread Starter
Cool. Im pretty tight on clearance to my intake tube. Does the hydro boost have about the footprint as far as length?
7091ram likes this.
1993 W250
post #10 of 34 (permalink) Old 01-16-2019, 09:53 PM Thread Starter
Little bit of progress. Finished the radiator, intercooler, and electric fan mounting.
ID:	838397   Click image for larger version
ID:	838399   Click image for larger version
ID:	838401   Click image for larger version
ID:	838403   Click image for larger version
1993 W250
post #11 of 34 (permalink) Old 01-22-2019, 09:55 PM Thread Starter
Still chugging away. Moved the 2 gas tank crossmembers forward 3”. Cut all the rivets off the leaf spring hangers and moved the axle forward 3”. Cut 4” off the back of the frame and boom! Wheelbase is where I want it..
ID:	838977   Click image for larger version
ID:	838979   Click image for larger version
ID:	838981   Click image for larger version
98whitelightnin likes this.
1993 W250
post #12 of 34 (permalink) Old 01-22-2019, 10:08 PM
Looking good
7091ram is offline
