Australian f250 12v swap - Page 3 - Dodge Cummins Diesel Forum
 7Likes
post #25 of 214 (permalink) Old 08-21-2018, 04:49 PM
Destroked 450's Avatar
Sent you a PM
Once you find out exactly what the engine is then we can discuss upgrades.
One upgrade I do recommend no matter what is a set of dual vented valve covers and plugging the factory tappet cover vent.
If you have a New Holland or Case ag/industrial equipment dealer near by they can get then for you.
If interested I'll get you the part numbers.
Mine-04 F-450 SCFB 4X4 drw,5.9 12v 215 Ppump,ZF 6,KYclutch,KDP fixed,gauges,5x12's,15deg,3k GSK,60#,AFC Live, Super B single,Pusher intake,D celebrator brake,07 coil spring front conversion.
Her's-18 F-150 STX SC, 4x4, 5.0
Toy- 64 Fairlane, future 406FE, 3 Holley 2bbls, 4 spd
Destroked 450 is offline
post #26 of 214 (permalink) Old 08-21-2018, 11:32 PM Thread Starter
gun32gtr's Avatar
Definitely do mate and part numbers be great thanks alot.
I will ring the bloke again sus him out about the engine numbers and plate
2003 f250 extracab
4.2 litre mwm sprint diesel soon to Be 12v 6bt p-pump,zf6 speed. Aiming for 350hp and 800 od nm
gun32gtr is offline
post #27 of 214 (permalink) Old 08-23-2018, 07:58 AM Thread Starter
gun32gtr's Avatar
Destroked450 what fuel plate did you use in your engine?Are the dynamite diesel ones the go or just another over priced ebay item
2003 f250 extracab
gun32gtr is offline
post #28 of 214 (permalink) Old 08-23-2018, 10:44 AM
Picked my #10 plate up on eBay for around $50 without the afc spring kit, got that from TST products $40
Presently I'm running AFC Live from Power Driven Diesel but haven't been able to get it completely tuned to work with my towing app like I want it.
Word of advice: Don't get carried away with a bunch of power mods at the beginning, that 215 pump as the potential to make good power with very few mods, i'd go with a #10 plate in the stock position and play with the star wheel and pre boost adjustments at first then work your way up with afc spring kits and governor springs.
Many have made several mods at the beginning and got lost trying to get the engine tuned properly, I did that myself and it took a while to understand what was needed.
thrashingcows likes this.
post #29 of 214 (permalink) Old 08-23-2018, 03:31 PM Thread Starter
gun32gtr's Avatar
Great advice mate im glad i asked cause i guarentee thats what would have happened to me as well.. ill be getting it tuned on a dyno to be safe as im not the greatest at tuning things apart from chainsaws ��
2003 f250 extracab
gun32gtr is offline
post #30 of 214 (permalink) Old 08-25-2018, 04:32 PM Thread Starter
gun32gtr's Avatar
Bloke i bought the engine off recommended if i go 300hp or a bit more to change valve springs. Is this true?
2003 f250 extracab
gun32gtr is offline
post #31 of 214 (permalink) Old 08-25-2018, 04:54 PM
Moderator
9297oldram's Avatar
I don't see a need for the heavier springs unless your using a exhaust brake or going to have 4,000 rpm gov spring.
9297oldram is offline
post #32 of 214 (permalink) Old 08-25-2018, 09:37 PM Thread Starter
gun32gtr's Avatar
for now ill be going with stock engine whilst i sort any issues that may arise. once its been going for few mnths ill go #10 plate and 4k gov spring
2003 f250 extracab
gun32gtr is offline
post #33 of 214 (permalink) Old 08-25-2018, 10:03 PM
With 4k gsk or an exhaust brake it's good to upgrade to heavier valve springs, even though not needed now it's a good time to swap the valve spring while the engines out.
Sorry I hadn't got back to you with those valve cover part numbers, been buzzy in the hay fields the last few days, I now know I can easily load 250 square bales on a 24 ft trailer deck.
Edit: I should have said the trailer would easily hold 250 square bales, it wore my 62 year old back side out loading them. The second load was just about more than I could handle.
Going to get the big round baler out tomorrow and roll hay in the cab tractor with the AC on.
post #34 of 214 (permalink) Old 08-25-2018, 10:24 PM
Here ya go.
Check with you NH or Case dealer to see what kind of deal you can get
This is for one dual vented valve cover, if you want two like many of us use you'll need to double the amount of each item
https://www.cumminsforum.com/forum/25423626-post14.html
Depending on shipping cost here'a another source.
https://puredieselpower.com/dodge-pr...-breather.html
post #35 of 214 (permalink) Old 08-26-2018, 06:58 AM Thread Starter
gun32gtr's Avatar
No exhaust brake and just ordered #10 fuel plate and 4k gov spring. But wont be revving it past about 3300rpm ill be tell the tuner.
2003 f250 extracab
gun32gtr is offline
post #36 of 214 (permalink) Old 08-26-2018, 07:01 AM Thread Starter
gun32gtr's Avatar
[QUOTE=Destroked 450;28704761]With 4k gsk or an exhaust brake it's good to upgrade to heavier valve springs, even though not needed now it's a good time to swap the valve spring while the engines out.
Thats crazy how much hay that thing can tow. Australia really does suck.. i need to move to the states haha.
I ordered the fuel plate and Gov spring today. If valves spring upgrade is cheap insurance i will do it i think..
And exhaust brake will be a future plan. They sound great and well saves ya pads abit wouldnt they
2003 f250 extracab
gun32gtr is offline
