Australian f250 12v swap - Page 11 - Dodge Cummins Diesel Forum
 7Likes
post #121 of 212 (permalink) Old 03-05-2019, 09:34 PM
Destroked 450's Avatar
Yours has the pump mounted on the back side of the gear case driven by the timing gears.
If the threads on the hub look good the fan clutch nut may have gotten mashed a little.
Aftermarket fan clutch is around $50 US, New OEM is around $175 US.
Arguments on both but I'd be willing to try a aftermarket Hayden brand.
Google Hayden 2798
Mine-04 F-450 SCFB 4X4 drw,5.9 12v 215 Ppump,ZF 6,KYclutch,KDP fixed,gauges,5x12's,15deg,3k GSK,60#,AFC Live, Super B single,Pusher intake,D celebrator brake,07 coil spring front conversion.
Her's-18 F-150 STX SC, 4x4, 5.0
Toy- 64 Fairlane, future 406FE, 3 Holley 2bbls, 4 spd
Destroked 450 is offline
post #122 of 212 (permalink) Old 03-06-2019, 02:14 AM
With the engine mounts I used the pump in the standard position was just too tight a fit.
Think I used a right side mount on both sides to get the engine low. The 2000 Dodge had a left and right mount.
I used both the angled ones.
Just meant a little more fabrication and belt routing.
The engine came with a single Vee belt driving the power steering and there was a Hydro boost pump in place of the vacuum pump.
That pulley was too far into the radiator to use.
All the fun of conversions.
Cheers Steve
86 F350 CC dually, RTO610, 3.32 final gears 93 5.9 (ex F600) basically stock,THD pin, tuning in progress
Blackduck59 is online now
post #123 of 212 (permalink) Old 03-06-2019, 02:29 AM
The style of fan hub with a Vee belt drive for power steering etc.
Cheers Steve
ID:	842677   Click image for larger version
ID:	842679   Click image for larger version
post #124 of 212 (permalink) Old 03-06-2019, 11:26 PM Thread Starter
gun32gtr's Avatar
Blackduck59 the 12v and cummins engines in Australia are not common so unfortunately i dont have many options it sucks. Ill have to go with what i have and make it work. Trim my fan shroud out toward the passenger side for me as im rhd. Your setup looks like a very solid setup. Is there any harm in running the tension pulley on the ribbed side of the belt or should i change the tension wheel to a ribbed one?
2003 f250 extracab
4.2 litre mwm sprint diesel soon to Be 12v 6bt p-pump,zf6 speed. Aiming for 350hp and 800 od nm
gun32gtr is offline
post #125 of 212 (permalink) Old 03-06-2019, 11:27 PM Thread Starter
gun32gtr's Avatar
Destroked450 did you run a one way valve on the bottom of your feed line down in the tank? I wonder if you did thats why mines running back out cause i never put anythung on the bottom. Hose just straight into the diesel and a little 250micron filter that goes into the flared an fitting
2003 f250 extracab
gun32gtr is offline
post #126 of 212 (permalink) Old 03-07-2019, 11:03 AM
No the lift pump has a check valve to hold the fuel, if it's draining back you have a leak in the line or a fittings between the lift pump and tank allowing air in.
Putting a check valve in back next to the tank will help hold the fuel up but won't stop air from being drawn in while the engines running.
Check all of the fittings and connections.
post #127 of 212 (permalink) Old 03-07-2019, 06:00 PM Thread Starter
gun32gtr's Avatar
Yeah ok sweet as. Ill pump fuel up again and gwt it running and leave for a day and see wht happens..if not ill fimd the leak cause as you said shouldnt drain back and the lift pump ws factory new when i bought the engine
2003 f250 extracab
gun32gtr is offline
post #128 of 212 (permalink) Old 03-07-2019, 06:32 PM
With the idler I would use a grooved pulley, running the grooves on flat one may reduce the life of the belt as you are running on the peaks of the groves.
Hear the bit about parts, sold that fan assembly to a guy in Queensland as I had no intention of running it. Then found I needed an extra idler to get the belt set up so had to get another fan hub.
Broke the first rule of converting, don't get rid of anything till the job is done.
Cheers Steve
The Following User Says Thank You to Blackduck59 For This Useful Post:
gun32gtr (03-24-2019)
post #129 of 212 (permalink) Old 03-07-2019, 08:35 PM Thread Starter
gun32gtr's Avatar
2003 f250 extracab
gun32gtr is offline
post #130 of 212 (permalink) Old 03-25-2019, 09:27 PM Thread Starter
gun32gtr's Avatar
anyone put a turbosmart iwg75 wastegate on the hx35. my stock wastegate on the hx35 is all bashed and dented so wanna change it out?
2003 f250 extracab
gun32gtr is offline
post #131 of 212 (permalink) Old 03-26-2019, 10:21 AM
That number came up for a Ford PS diesel set for 21 psi boost max.
Ford PS computer will default when boost pressure goes over 27 psi, a stock 12v Cummins will make 21 psi easily and a hx35 will operate dependably at 30-35 psi.
If the mounting bracket is bent up look at a AFE 46-60118, comes preset to 40 psi but I'd adjust it down to 35 psi max.
Your giving up a good amount of power with any actuator that won't allow at lease 30 psi boost.
post #132 of 212 (permalink) Old 03-26-2019, 08:15 PM Thread Starter
gun32gtr's Avatar
yeah after some more research the turbosmart was bolt on for the 24v cummins turbo not hx35 i have.
i will order the one you have gave me the part number for. thanks alot.
p.s wrote my daily run around off last Sunday so the pressure is on to finish the truck now
2003 f250 extracab
gun32gtr is offline
