05 1500 ram 6.7 swap! - Page 2 - Dodge Cummins Diesel Forum
 7Likes
post #13 of 56 (permalink) Old 02-11-2018, 10:59 AM
Fanman43's Avatar
(because I'm curious) If he were to use the TIPM/PCM/ECM (not all that sure what would be applicable) and harness' out of a 7.5 - 09 truck, wouldnt he be able to utilize the 6.7 injectors? It sounds to me that he is already going to need to custom tune it all any how, so why would the firing voltage matter? My concern would be having to turn up the 5.9 injectors to help with the greater displacement.
Asking because I genuinely don't know.
2007.5 DODGE RAM 3500 QCDRW - 6.7L CUMMINS FULL DELETE - H&S INTAKE HORN - AFE AIR INTAKE - ARP HEAD STUDS - EFI LIVE BY STARLITE DIESEL - FASS TITANIUM - BEANS DIESEL SUMP - STRAIGHT PIPED - G56 6 SPEED TRANS
Fanman43 is offline
post #14 of 56 (permalink) Old 02-11-2018, 11:16 AM
Dylanss180's Avatar
Be careful with running 6.7 injectors on a 5.9 ECM. They use different voltages and amps. Some say it can be done but with some massive hiccups on startup.
I am swapping my 2003 5.9 with an 2016 6.7 and I am swapping out all injectors and harnesses back to run all electronic stuff for the 2003 so it will be plug and play. Good luck man.
2003 Ram
Dylanss180 is offline
post #15 of 56 (permalink) Old 04-08-2018, 11:41 PM Thread Starter
Crank is finally done and coming back to be with new bearings for the connecting rods included next time I will just take it myself rather than have a buddy relay it to the machine shop lol.
2012 deleted MegaCab on 37" MT and 6" lift
2005 Ram 1500 soon to be 6.7 swapped
Charged392 is offline
post #16 of 56 (permalink) Old 04-21-2018, 04:27 PM Thread Starter
The crank is home. Turned down 10/10 so on size thicker bearings and good to go. Not going crazy with power on this setup.
Ordering painless wiring harness for a 2005 truck/pcm setup. Getting a manual 5.9 pcm for this swap since 727 trans being used .Using all the 6.7 electronics and what not just switching over the few pigtails I need and the 2005 rail psi sensor. Test for and mock up coming soon got a few side jobs rolling right now and barn is tied up!
post #17 of 56 (permalink) Old 04-21-2018, 09:25 PM
Fanman43's Avatar
Cant wait to see it all come together! Keep up the good work!
Fanman43 is offline
post #18 of 56 (permalink) Old 06-02-2018, 07:28 AM Thread Starter
All bearings and seals are on the way. Rebuild coming soon! Once I have rebuilt doing test install and mock-up with complete motor. Once I have it fitting nice and good will get wiring and pcm to start it up
post #19 of 56 (permalink) Old 06-06-2018, 11:11 PM Thread Starter
I know it seems like this is taking forever but I am a very busy guy this time of year and vacation is coming but look what came in finally. The bearings have arrived so I can now get the cam and crank into the block and start this fun project.
post #20 of 56 (permalink) Old 06-09-2018, 11:21 PM Thread Starter
Took my pressure washer to the bunker up motor lol and this is how it came out after. Itís rrally clean had to remove galley plugs and what not to clear out the passages. I am shocked as to how simple the cummins oil flow path is. The oil squirters are all clear also. Went to drop crank in and they shipped me standard mains when I know for a fact I ordered .025 thicker ones. So gotta call them Monday and get this sorted out so I can get rolling on this assembly. The down time I will Be porting the stock air horn and removing the turbo vgt motor to do a mechanical wastegate rod setup with a cable brake setup.
ID:	815489   Click image for larger version
post #21 of 56 (permalink) Old 06-16-2018, 01:02 AM Thread Starter
Crank is in the engine!
Cam is in the engine!
Cover is all sealed up on the motor!
Next is the fun task of cleaning the head off and resealing the stems because I donít want to risk a messed up seal leak from this sludge mess!
ID:	817713   Click image for larger version
ID:	817721   Click image for larger version
The Following User Says Thank You to Charged392 For This Useful Post:
StealthDiesel (Yesterday)
post #22 of 56 (permalink) Old 06-16-2018, 01:17 AM
Fanman43's Avatar
are you having the head machined?
What cover is that?
That Crank is purty lookin!
Fanman43 is offline
post #23 of 56 (permalink) Old 06-16-2018, 07:04 AM Thread Starter
Not machining the head no overheat and very low miles clean really good an go should be more than good. I am re sealing it with new valve stem seals.
Thatís what they call there timing cover lol.
post #24 of 56 (permalink) Old 06-16-2018, 02:54 PM
Ducati M.
DMan1198's Avatar
A note on using a mechanical setup on the vgt. They don’t provide the best performance characteristics. You’re far better off using the electrical actuator, and tuning it by shaft speed. @Rx7man, and one other 2nd genner whose username eludes me would be the guys to talk to about setting them up properly without using a cm2100, or newer ecm.
hookit likes this.
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM3 w/Warp, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan, build thread
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
The Huntress- 02 VW Jetta tdi, 5 speed, egr/muffler delete, 11mm ve, gt1749v, ISSPRO factory match.
click here for Instagram: dsmdiesel
DMan1198 is offline
