84 K5 Blazer 12v 47re build - Page 15 - Dodge Cummins Diesel Forum
 21Likes
post #169 of 180 (permalink) Old 12-20-2018, 11:59 AM Thread Starter
9297oldram's Avatar
Originally Posted by Destroked 450 View Post
Tractor project? Are we talking about the trencher or a tractor, I like tractor projects, have a few of my own.
The trencher now tractor, I also have a Deutz Diesel standalone project there in the same section.
https://www.mytractorforum.com/119-h...r-project.html
9297oldram is offline
post #170 of 180 (permalink) Old 12-20-2018, 01:07 PM
Destroked 450's Avatar
Ok, I'm on a couple other tractor forums but not that one, I have 7 farm tractors, 5 operational, 4 used regularly for farm work and 2 project tractors to be used on the farm when completed.
All Fords.
I have a 3 cylinder Deutz engine on a snorkel lift, the drive hub on the rear connects to a hydraulic pump to power the machine.
Mine-04 F-450 SCFB 4X4 drw,5.9 12v 215 Ppump,ZF 6,KYclutch,KDP fixed,gauges,5x12's,15deg,3k GSK,60#,AFC Live, Super B single,Pusher intake,D celebrator brake,07 coil spring front conversion.
Her's-18 F-150 STX SC, 4x4, 5.0
Toy- 64 Fairlane, future 406FE, 3 Holley 2bbls, 4 spd
Destroked 450 is offline
post #171 of 180 (permalink) Old 12-20-2018, 01:13 PM Thread Starter
9297oldram's Avatar
All Fords.
I had a friend with a small machine shop fix me up a shaft that went into the hub and the generator pulley is off that then on the end of the shaft is a Lovejoy that i'm going to couple a hyd pump to that i'll run my log splitter from. That 'll save extra hours on my tractor.
post #172 of 180 (permalink) Old 02-02-2019, 02:12 PM Thread Starter
9297oldram's Avatar
I got 2 of these in the mail today one for the Blazer and one for the Ford, will make it nicer for plugging in the block heaters.
The Following User Says Thank You to 9297oldram For This Useful Post:
WAYNES WORLD (02-02-2019)
post #173 of 180 (permalink) Old 02-02-2019, 02:57 PM
Cummins Crazy
WAYNES WORLD's Avatar
9297oldram,
Nice setup, where did you find them?
WAYNES WORLD
96,Lil Pete,12v GB td & trans, Stainless Twins
Dual 5" stacks, 13MM & 5x18's
WAYNES WORLD is offline
post #174 of 180 (permalink) Old 02-02-2019, 03:48 PM Thread Starter
9297oldram's Avatar
It's a nice setup for the money and the plug for the hole on the outside fits tight.
post #175 of 180 (permalink) Old 06-12-2019, 03:45 PM
Dchamber's Avatar
Originally Posted by 9297oldram View Post
The UPS man brought me a very hard to find part to my puzzle. I found someone that makes these vacuum pump delete's, very nice piece.
Where did you get this from?
Sorry if you already said.
Dchamber is offline
post #176 of 180 (permalink) Old 07-20-2019, 03:29 PM Thread Starter
9297oldram's Avatar
I've been noticing that for the last couple weeks the starters not engaging on my 2 year old store bought rebuilt starter. I ordered a set of Larry B's starter contacts and got them Wednesday and was going to put them on when I got a chance. This morning I was in my driveway putting my trailer on and shut it off to do something and when I came back guess what, it wouldn't start just click. So I unhooked my trailer and got my tractor to move the trailer into the yard so I can get the Ford out and also used the tractor to push the Blazer into the shade to repair.
When I started tearing the starter down for the new contacts the big battery lugs weren't very tight. Installed the new parts and put it on and guess what it still wouldn't start, after checking my battery cables and cleaning then the last one was the ground on the engine which is a pain to get to. Put my sock on and went to turn it off and guess what there was no resistance on the bolt, so I tightened up the bolt ans it started. Who would of know that a bad ground would have caused the same symptoms, LOL.
I always tell everyone when having electrical problems check your cables and grounds, should have practiced what I preach. I wanted to do the contacts anyway but just not on a 90 degree day ouitside in the shade fighting off the mosquitoes and gnats.
post #177 of 180 (permalink) Old 07-21-2019, 01:20 AM
Nothing ever breaks down on a nice day when you have time to fix it.
Bigbronco94 likes this.
post #178 of 180 (permalink) Old 07-21-2019, 08:01 PM Thread Starter
9297oldram's Avatar
I'm just thankful it broke down where it did and not where I was going with the trailer attached to it.
post #179 of 180 (permalink) Old 07-24-2019, 01:41 PM
I might have missed it, but what did you do for engine mounts? Can the factory ones be used on the chev or do you need to cut them off and weld a custom set on? Hoping to do a square body suburban in the next few years and want to get a decent idea on some of the details.
Thanks
1993 W250, G-360 manual completely stock.
Shelby/Dakota is offline
post #180 of 180 (permalink) Old 07-24-2019, 01:58 PM Thread Starter
9297oldram's Avatar
Thanks
I used 2nd Gen engine mounts and a frame kit from Rob Bonny Fab. There's a picture of the kit on the 1st page.
