A K5 Cummins Conversion: The saga continues... - Page 2 - Dodge Cummins Diesel Forum
 4Likes
post #13 of 49 (permalink) Old 03-06-2017, 02:08 AM Thread Starter
MaxPF's Avatar
OK, so I got axles in, Yay... But I still can't even roll the truck forward because I don't have a tie rod to keep the front wheels straight. Well, remember those built-by-Todd parts in the cardboard egg tray in the previous posts? They just happen to be ⅞-18 right and left hand tapped bosses for building tie rods, drag links, and Panhard bars. I combined one right and one left with a suitable length of 1- .120" wall 4130, some TIG welding, a coating of wrinkle paint, and some tie rod ends from Parts Mike end ended up with this:
Now that I had a rolling chassis again, I could address the next item: a transmission. I was originally going to run an Allison, and even had one built and ready to go, but I sold it to someone who needed it worse than I did. Then I brought home an Eaton-Fuller FS-6406. I got it for a good price, and planned on throwing OD gears into it, but it was just too much trans for a Blazer. A one ton truck that tows a lot (and routinely breaks NV5600s and G56's), yeah it's the hot ticket, but a 365lb 6 speed is just too much gearbox for a K5. I would have to substantially surgically alter the floor and firewall to accommodate the trans, and i just didn't have it in me anymore. So I sold it off to a guy who actually needs it for his dually on 37's.
I still needed a trans, and there was only one practical choice. The problem is, I don't like it. I'm talking about the NV4500, and anyone who knows me knows I hold this trans in very low regard. The first through fourth gear portion is decent enough (although the 465 is better IMO), but fifth gear is a complete crap design, and the gearbox has smallish countershaft bearings. OTOH, it can be fixed up and it has the OD I need, so it's what I ended up with if I ever want this heap to roll under it's own power again.
Because I wanted to run a round pattern 205 that I already have, and it has a GM bolt pattern and GM 32 spline input, I chose to run a late GM NV4500. Parts are interchangeable with the Dodge version, which allowed me to run the aftermarket 1-⅜" input shaft designed for hot-rodded Cummins apps. I found one for sale from a guy on 4BTswaps for a good price. It was out of a 350 Vortec truck, so it had no mainshaft damper but a spacer sleeve instead. Not a big deal, but the damper was put on the units that went behind the 4.3 V6 to keep gear rattle down, so I expect I may end up with some gear rattle. We shall see. Anyways, here's the trans in pieces:
If you look at the following pic you will see that the end of the countershaft has 16 wide-spaced splines in it. The shaft can accommodate 48 splines that size, but New Venture chose to only run a third of the maximum. Why? I dunno. SInce the input-to-countershaft multiplication is something like 1.8:1 there is a LOT of torque applied to those splines when at full throttle, even in a gas motor. That they survive at all is a miracle.
Usually, it is the mainshaft gear that has issues. It's small and retained with a spanner nut. Over time the torque can work the gear back and forth, eventually working the nut loose. The nut backs off and the gear follows it, walking off the splines. There are numerous fixes, but my favorite is this. Unfortunately, they only make that lock for the Dodge 29 spline shaft, so I used a piece of female 32 spline input that was cut off of a NP241 and a piece of chromoly tubing with 4 tangs cut in it, welded it together, and made my own.
The 4500 does have one outstanding feature: good synchros.
Those fiber-layered rings make the synchros work way better than older grooved brass synchros in transmissions like the 465. The only drawback is that they work best with the special fluid made by Castrol with costs $20 a QUART! And the trans holds a GALLON! Since the trans doesn't oil well with only a gallon it is recommended to put 4.5 quarts in it, so I was forced to buy 5 quarts. Did I mention it's $20 a quart? Yay....
I did need two new hard parts though. The synchros in third were completely wasted, and the owner obviously kept grinding it to find it. This destroyed the 3-4 slider and the coupler splines on the third synchro hub. I was lucky that a fellow wheeler had a good assortment of NV4500 parts on hand and was able to hook me up. Other than that the trans was in very good shape. I was even able to re-use the bearings, although how long they will last behind a Cummins I can't say. I did put all new synchros in the trans, of course.
Eventually I got it all together:
Those with sharp eyes and familiar with the NV4500 will notice that the bolts retaining the aluminum tailhousing aren't the stock 12-point New Venture units. I managed to windmill the head on one of them, and the rest were a bit sketchy. Regular 6 point bolts don't leave enough clearance for the socket, so I used metric Allen bolts instead.
MaxPF is offline
post #14 of 49 (permalink) Old 03-06-2017, 02:12 AM Thread Starter
MaxPF's Avatar
Next up was this pile o' parts:
That is my round pattern 205, all cleaned up and ready to re-assemble.
By this time I had acquired an audience of sorts:
With my pal the dragonfly watching my back I worked on getting the t-case assembled. One thing I never liked with the 205 was the fact that the shifter shafts would get grooves rusted in them right at the seal, which would often cause some leakage, and mine were in pretty bad shape New ones are available, but they are spendy and still made out of steel. So, I ordered some .750 ground rod in 17-4PH stainless steel. Then I carefully blueprinted the stock shafts (minus the rust grooves) and gave the rod and the blueprints to Todd. A week later I had a set of stainless steel 205 shifter shafts. I actually modified the blueprint to make the shafts twin-stickable. Might as well, right? Never know when I might need to do a front dig
The shafts were machined, but still needed to be heat treated. The nice thing about 17-4 is the simple heat treat: 900F for one hour then air cool. Since it is a precipitation hardening alloy there is no oil quench or temper steps needed. That made it extra easy to do myself in my little heat treat oven. Here's the result:
The cool color is the thin layer of chromium oxide that forms at 900F in air. I was going to Scotch-Brite it off, but I decided it looked cool so I left it alone.
About this time the Law Of Murphy kicked in. Turns out, the stock shafts measured .748" not because of loose tolerances, but because the bores in the shift forks were reamed to EXACTLY .750"! Actually, they were .7497" when measured with a dial bore, while my precision ground 17-4 stainless rod mic'd at .7504 after heat treat. A press fit. Which makes it essentially impossible to assemble :dohh: Luckily, the bores in the case were bigger, so the shafts fit there. They were a bit sticky without oil, but with oil they were perfect.
I chose a [cough]crude hack[/cough] simple, expedient method of enlarging the bores in the forks:
Good to go!
The next item to address were the front and rear flanges. The rear flange was a High Angle Driveline unit from my 241. I had originally ordered it for a 205, but decided to run the 241 behind the 465. The 241 uses a smaller diameter seal surface, so I had to turn down and sand the seal area on the flange to fit. Somehow, I stepped on my crank and made it a bit undersized. It still contacted the seal, but barely. The result was a profuse weep that would slowly coat the area above the flange with a thin coat of ATF. Yay.... Since I intended to re-use the $100 flange with the 205, I needed a seal that would fit the seal retainer in the 205 AND properly fit the flange. No-go. There were seals that fit the 205 retainer ID and fit what the OD of the flange sealing surface was SUPPOSED to be, but none that would fit one a few thou undersize Swell.
Then there was the front Saginaw flange that had a nice fat groove right where the seal runs. The groove was caused by... (drumroll) rust! Not wear. Just like the shafts, it gets water spray and seldom moves, so it rusts right at the seal. I had a couple options with the front: the cheapest and easiest was to use a seal with a thinner body that I could set back a bit so it would ride on a groove-free part of the flange. Or, I could buy a new Saginaw flange. Or, I could buy a 32 spline $100 HAD flange like I had on the rear (I put a 32 spline front output in during the rebuild )
It was at this point a had a "Duh!" moment. Speedi-sleeves! Use Speedi-sleeves dood! And that is exactly what I did:
These are slick. They repair grooved shafts, giving a new, wear-resistant sealing surface with a perfect surface finish for best sealing and wear. They're also made of stainless steel, so no rust grooves! :thumbs: Since they are several thou in thickness they will also fix my slightly undersize rear flange. Perfect!
Here's how they work: First you put the part on and make a mark just above the seal, so you know how far to drive the sleeve on:
Then, put some anaerobic sealant (or Hylomar in my case) on the shaft and drive the seal into position with a hammer and the included driver tool:
Next you need to remove the flange that the installer tool drives against. You snip it with a set of cutters:
Then break it free with a pair of pliers and peel it off around the pre-scored line:
Clean off whatever goo you used as sealant:
And verify your handiwork:
The front Saginaw flange got the same treatment:
Continued...
MaxPF is offline
post #15 of 49 (permalink) Old 03-06-2017, 02:15 AM Thread Starter
MaxPF's Avatar
The next problem to solve is the fact that the speedo housing on this 205 is for a cable speedo, and my truck has an electronic speedometer. Electonic speedo housings for the 205 do exist, but they are rare as hen's teeth. They were only made in 1990-1991, and only in 1-ton crew cab pickups. In other words, they are impossible to find, and if you do you'll pay dearly for it.
Once again, I had options: Either use an electronic speedo pickup that threads into the cable speedo drive, or modify my housing for a VSS and replace the speedo drive gear with a 40 tooth reluctor. I chose the latter option since it is a bit cleaner. It involved marking the housing with dimensions using a Sharpie, and giving it to Todd to drill, counterbore a flat seat, and tap for the VSS:
As it turns out, the speedo gear/reluctor splines on the 241 are the same as a 205, and I just happened to have a 241 reluctor. It's wider than the 205 gear, so I turned equal amounts off both faces until it was the same width as the 205 speedo gear. When I went to assemble it I found a cast boss in the housing hit the reluctor, so I had to use a rotary file to cut away the tip of the boss. Here's the result:
This is the boss I had to cut down:
The finished product:
In that last pic you can see the hole where the cable speedo drive threaded in. I have the piece that screws in there, and I welded a -6AN male fitting to it and put a cap on it. It makes an excellent fill port for a clocked 205, and it will serve another purpose...
Finally, I needed two other items to make the case ready to install. First was a spacer/clocking ring. I could have used the short 32 spline input and cut a notch in the 4500 tailhousing to clear the rear shifter shaft, but I didn't really want to. Plus, I wanted to clock the case up, and the ⅜" thick clocking rings usually used are prone to leaking. A spacer to allow use of the long input will eliminate the need to cut the 4500 tailhousing, and it is thick enough that it won't warp and leak. So, I drew it up on Solidworks, emailed Todd the file, brought him a piece of aluminum. It turns out the aluminum was a hair too short, so I TIG welded an aluminum bead around the pilot ring to give the needed extra material. If you look close you can see the where it was welded. Without that extra material the pilot was barely (like a few thou) too short when a gasket was used between the trans and spacer.
In that pic you can also see the second final item I needed: a linkage to actuate the rear shifter shaft. Once the case is bolted to the trans, that shaft is only accessible from the side, so a linkage is needed to hook up a shift rod or cable. The red aluminum Heim joint is where the shifter rod will attach. The linkage and bracket holding it are all stainless steel, so no paint is needed
That's it for now. On the next episode, I'm gonna get dirty
MaxPF is offline
post #16 of 49 (permalink) Old 03-07-2017, 01:03 AM Thread Starter
MaxPF's Avatar
With a transmission and transfer case ready I needed a new crossmember. However, I wanted to add reinforcement to the spliced frame area first. I got some more " steel plate and used it to box in the spliced section:
Welds still look like . I have never had so much spatter from MIG. I figure it was probably the weld-through primer, but maybe I just had a case of the yips? I dunno - I'm just glad it's hidden under the truck! They are structurally sound though, and that's what matters most, right? Bah, who am I kidding! It's all about the looks!
Here's the crossmember I came up with:
The welds on the crossmember look great! Why? Because I TIG welded it. So, was it the weld-through primer, bad conduit/hose assembly on the MIG welder, or a case of the yips? I still haven't figured it out...
It was right around this time that I had finally had it with my leaky- engine. Off with it's head!
Hey, there's a camshaft there as well! And look at this pile of parts:
Oh yeah. I tore everything apart.
In that pic the oil pump is still on the engine. It got pulled off as well, as I will explain in a moment.
Here's what the deck looks like:
Yeah, it's as bad as it looks. Check out the oil sludge on top of the oil cooler area! I have no idea where it all came from, but it was nasty!
Here's my creative method of holding the lifters up:
I never knew International cast blocks and heads for Cummins, but both the block and head on my engine sported the International logo:
After cleaning the head and deck it got put back on with a new Cummins gasket AND new bolts.
Not only was the front timing cover leaking between the cover and block (gushing would be a more appropriate term), but all the bolts were scary loose. The stock fiber gasket had long since shrank and turned to rock, so the leaks and loose bolts weren't really surprising. I was worried about the oil pump bolts, but they were still tight. I removed it anyway so I could tape up the block and Roloc all the rock/gasket material off. Then I cleaned every bolt hole with brake cleaner and a rifle brush. I installed the oil pump using Loctite on the bolt threads. Then I coated the block-to-cover gasket with a thin layer of Ultra Black, put the cover on the dowels, and used Loctite on all the cover bolts. I do NOT EVER want more leaks!
I had replaced the seal on the tappet cover, and that ****** STILL leaked, so it got cleaned and Ultra-Blacked as well, No leaks!
Finally, the oil cooler gaskets were leaking like a sieve, so it got pulled apart as well. The old gaskets were more fiber/rock units. At some point Cummins must've realized those gaskets were crap because the new ones were rubber coated metal shim gaskets. Finally, modern technology! No leaks! Now, having seen the results of a Cummins oil cooler failure (which I later found out was actually an oil cooler gasket failure), I got paranoid and put a brand new oil cooler on the engine while I was at it Hey, anyone know what's on the menu at the local soup kitchen?
Oh yeah, one other thing. I always thought my new rear main seal was leaking. Turns out it was dry as a bone. The leak was coming from the welch plug in the rear of the cam bore. I discovered this AFTER I re-sealed the front and had it all put back together and I was NOT going to tear it all apart just to pop out the cam plug. I thought about trying to put a hole in it with a punch and prying it out (or using a screw and a slide hammer), but if it didn't work I would have to pull the cam again. My ultimate fix was [cough]a total hack[/cough] expedient: I thoroughly cleaned the flywheel housing and the rear block face, but a coat of The Right Stuff around the cam plug, and reinstalled the flywheel housing. Since it is machined surface-to-machined surface, the problem should be solved.
Whew! Is this thing ever going to run again? Keep watching and find out!
MaxPF is offline
post #17 of 49 (permalink) Old 03-07-2017, 01:25 AM Thread Starter
MaxPF's Avatar
The next thing I addressed was the turbo oil drain. When I pulled the boost tube off during the reseal there was a fair bit of oil on the inside. The oil could be due to one or more reasons: Maybe the turbo seals aren't sealing? Maybe there is too much oil feed? Maybe my drain didn't have a steep enough slope?
I decided to address the latter two potential issues. If the turbo seals aren't working I will need either a new turbo (HE351VE would be sweet!) or more new parts for my WH1C. Now, the problem with fixing the drain is that I would have to redo the right side motor mount in order for the drain line to have a straight shot. Since I wan't really happy with the mounts anyway I figured I may as well replace them both.
The previous mounts, using urethane spring bushings, absorbed engine vibes quite well so I saw no reason not to use the spring bushings in the new mounts. I liked the tube mounts Todd built for the LQ4 engine in his Jeep, so I figured I would make tube mounts as well. This is what I ended up with:
The tube between the engine-side plate and the bushing is 1-" .120" wall 4130, with a wedge of the same welded in as a gusset. Assuming the welds don't crack it should be plenty strong.
Here is the right side mount along with the new turbo drain plumbing:
Along with the mounts proper I also modified the frame-side mount perches and made a new crossmember that better ties both sides together:
In the last pic you can also see my drag link. The bends were needed for oil pan clearance when the right side is at full stuff. It still hasn't been fully tested..... The crossmember works great though. I can jack one side up and there is no frame twist or flex.
The other item I addressed was the turbo feed line. I made a new one using reuseable fittings and steel braided Teflon hose since the old one had rubbed on something and got frayed in one spot. What you can't see is the fitting going into the turbo that restricts the feed to the same size orifice as the stock banjo fitting.
In stock form the fuel and brake lines run down the passenger (right) side of the truck. Unfortunately, the Cummins also runs it's exhaust down the right side. I figured this was as good a time as any to put new fuel lines down the drivers side frame rail. I decided to use the same reinforced nylon diesel fuel line used in MD and HD trucks, tractors,, etc. It's inexpensive and tough. I didn't care for the use of brass compression fittings though, so I used barbed AN fittings. What I did was heat the end of the hose with a heat gun to soften it a bit, them press it onto the barb. I also put an HNBR o-ring between the first and second barb before pressing the hose on to ensure there would be no air leaks. Air leaks would be A Bad Thing.
That is the return line which doesn't need 3/8" ID tubing, but I liked the idea of having just one size of fuel line. Here's the return line dropping down, and you can see the supply line going into the lift pimp:
The supply line comes straight from the Racor filter, which I relocated to the frame rail:
Here's a better look at the Racor. It will certainly need a heavy skid plate to protect the plastic bowl, but being positioned on the frame rail means it is siphon fed from the tank so I can open the water drain or even change the filter without letting air into the system:
I used plenty of Adel clamps to secure the lines:
I also got the trans and t-case installed. Maybe I didn't look hard enough, but I didn't find anyone who made the wide truck trans mounts in urethane, and the parts store rubber ones are crap, so I used another spring bushing:
I also needed a new clutch master cylinder mount since the old one went with the old master when I sold off the 465 setup:
One real annoying item was my clutch pedal squeak. I ended up pulling both the clutch and brake pedals and replacing the bushings. I also eliminated the stock-type clutch rod and replaced it with one made from tube and using a Heim joint to attach the rod to the pedal. Major improvement!
That's it for now, but stay tuned; I ain't done yet!
MaxPF is offline
post #18 of 49 (permalink) Old 03-07-2017, 01:29 AM Thread Starter
MaxPF's Avatar
Not having a running truck didn't stop me from making it up to the North Kaibab plateau. Here's some pics off the southwest side:
That was an enjoyable trip, except for one thing: since I didn't have my own vehicle I couldn't go exploring wherever I wanted. This made me double my efforts to get my ride going. That North Kaibab trip was in October of last year, and I made up my mind that my truck would be driveable by Christmas. Time to get on it!
At some point earlier in 2015 I had redone my fuel tank pickup. It still had the old TBI in-tank assembly, and I had simply removed the TBI pump and welded a short inlet pipe to the pump holder with a piece of hose coupling the whole mess. I had used fuel injection hose designed to be submerged in gasoline and it was still in excellent shape, but I wanted to eliminate rubber hose from the inside of the tank. I ended up replacing the supply, return, and vent tubes with one-piece stainless steel tubes. I also added an extra " dip tube for a future add-on. All tubes were brazed into the stock unit after the original tubes were drilled out, and then had steel AN fittings brazed onto their ends for fuel line connections. I also put an anti-vortex cap on the suction dip tube. Here's a pic of the top of the tank with the fuel lines hooked up:
The line on the left is the supply (suction), the next to the right is the vent, and the one farthest to the right is the return. The capped fitting on the left is a " dip tube for a future add-on. I should note that the vent line is " air brake line that I heated and flared, allowing to to be directly attached with the same flare nut and backer used for metal tubing. Due to the positioning of the fittings I had to bring the supply and vent lines in down the center of the tank. This left them hanging in space above the axle, so I fabbed a simple aluminum bracket to support the lines:
I built a new PS reservoir (filler neck machined by Todd):
and added a PS fluid filter:
I've had it with push-on hose though. It likes to split the outer sheath, as you can see in that last pic. It doesn't seem to do any harm, but it looks like crap. Since the fittings aren't any cheaper I see no reason to use them over the regular reuseable AN fittings. I intend to replace them with reuseable fittings and Starlite hose over time.
The next item to tackle was my accessory belt setup. I wasn't happy with the amount of wrap on the AC and fan drive, so I needed to do something about that. I kept most of what I had already built, but I added one idler pulley and moved the tensioner:
The tensioner bracket meant that the stock lower water neck wouldn't work, so I made a new one out of a piece of " plate and a piece of 2" DOM which is turned down to 1-" to accept a common size hose:
My previous fan pulley mount was the stock jobbie that came on the engine, slotted and hacked to move it as far down and to the drivers side as possible. This time around I got Todd to build me a new one:
Next up: more plumbing... yay....
MaxPF is offline
post #19 of 49 (permalink) Old 03-07-2017, 01:32 AM Thread Starter
MaxPF's Avatar
I promised plumbing, so here we go! I already mentioned that I moved the fuel lines to the drivers side frame rail due to the fact that the exhaust runs down the passenger side, and the lift pump is located on the drivers side of the engine. Likewise, I decided to relocate the brake lines to the drivers side frame rail
I would have preferred to use stainless steel for the brake lines, but it requires expensive tools to double flare, so I chose to use cupronickel line instead. Cupronickel is typically 90% copper 10% nickel, although I have found some alloys that also included iron. In any case, the purpose of the nickel is to prevent the copper from work hardening and cracking. OE's used the stuff many years ago, but they went to steel due to cost..
Anyway, I am using the same 1 ton master cylinder and hydroboost that I had on before. I eliminated the stock prop valve/RWAL unit because it didn't proportion properly with rear disk brakes. I replaced it with an adjustable unit from Wilwood, mounted to a custom bracket:
The hard lines run down the firewall, then transition to a pair of Teflon soft lines to bridge the body-to-frame gap. Here is where the hard lines reconnect on the frame side:
The line on the left is 3/16" and goes to the rear brakes. The line on the right is " and goes to the front. The 3/16" line had to pass through the boxed section of frame, but there was no way to clamp it in there and it was too long of a span to have unsupported. I solved the problem by running it through a piece of ⅜" stainless tubing with flared ends (to avoid cutting into the soft cupronickel) and supporting the more rigid stainless tube at both ends:
Bracket that drops rear Teflon line to the axle:
Up front, the " line heads to a tee on the front crossmember. You also see the 3/16" line feeding the drivers side caliper, with plenty of Adel clamps retaining everything:
Tee on front crossmember with 3/16" lines heading off to each front caliper:
Caliper hoses are new. I used Teflon brake hose rather than rubber:
I also got vent lines hooked up. I used " air brake line for the vent tubes and connected them with either AN fittings or, in the case of the transmission and axles, using an intermediate rubber hose:
So that's it for now. Nothing exciting, but it's amazing just how much time this all takes...
MaxPF is offline
post #20 of 49 (permalink) Old 03-07-2017, 01:33 AM Thread Starter
MaxPF's Avatar
One thing I really wanted to add during this revamp was an intercooler. I knew it would help fuel economy a bit, but mainly it would help keep EGTs in check during long pulls up a grade. It would also be necessary if I wanted to utilize my new injectors and #6 fuel plate. However, in order to fit an air-to-air intercooler I would have to put the radiator back to the stock position, which would in turn mean i would have to procure an un-molested core support and somehow finding a fan that would fit in the meager space available. The alternative would be to run a liqud-to-air IC, but that means more parts. and potentially less efficiency. What to do?
Here's what I did:
Yup, I returned to an unmolested core support, built brackets, and stuffed a 12"x24"x3" core IC in front. Now, as I mentioned, this would mean I need to find a fan that will fit in the narrow space between the big radiator and the engine. Said fan needs to be able to pull a lot more air than the 6.2 fan was able to muster. I found just the fan:
I had to get it nice and close to the engine accessories in order to maximize space between it and the radiator:
I sanded the core support and IC mounting brackets, primed em, and sprayed 'em with PPG acrylic urethane:
Right behind the IC and between it and the condenser I fitted a Long stacked-plate cooler for the PS fluid. Here you can see it peeking out the side:
Here it is with the big radiator (late 90's 454 radiator). There isn't a ton of room between the fan and radiator, but it's enough:
Here's another view. Yup, there's a condenser in there too!
Another issue created by the addition of the IC is an inlet elbow on the intake manifold. The aftermarket ones were a bit too pricey for my taste, so I had settled on building one. At some point I started playing with the old one I had made, and it looked like it could work if the plumbing would clear the brake master cylinder. After some checking and double checking I decided it would work, so I cleaned it up, sprayed it with my usual wrinkle black, and baked it. Here's the finished product:
Next up: exhaust! My favoritest thing! [/sarcasm]
MaxPF is offline
post #21 of 49 (permalink) Old 03-07-2017, 01:35 AM Thread Starter
MaxPF's Avatar
So, last time I updated the thread I was about to get some exhaust going. It's just your basic 3" aluminized system,starting with a downpipe:
I decided to reuse my Magnaflow muffler:
It really tones down the exhaust and eliminates any in-cab drone despite being a straight-through design:
Complete exhaust system:
Gotta wrap the downpipe to keep the heat down:
A few installed pics. I had to route the exhaust on the outside of the trans crossmember due to lack of clearance inside:
And, of course, the honkin' 4" tip!
MaxPF is offline
post #22 of 49 (permalink) Old 03-07-2017, 01:36 AM Thread Starter
MaxPF's Avatar
Since the exhaust was now good to go, I needed some intake plumbing. I was leery of all the Chinese silicone couplers out there, so I opted for Gates couplers used for MD/HD trucks and equipment. I got simple straight couplers that I could cut to length for areas where little flex was needed:
I also needed one flexible coupling on each side, so I got a pair of ring-retained hump hoses:
Note the "Made In USA" on the hoses :metal: I also got some constant-tension t-bolt clamps to retain the hoses.
I also needed tubing. Some of the stuff I found was ridiculously expensive. I ended up using Chinese aluminum u-bends because I could actually afford them. I made a simple bead tool to put a bead on the ends, and after some :cuss:, , , and I ended up with these:
Starting at the turbo:
Through the core support:
Into and out of the intercooler:
Back through the core support:
Around the extra-wide diesel radiator, which other swappers assured me COULD NOT be done:
A hump hose mid-pipe:
And finally into the intake elbow:
I had to use regular hose clamps here because the constant tension clamps were too wide. In case your wondering, yes, it does clear the master cylinder. Barely:
There was one other minor thing I wanted before I threw the batteries in and took it for a spin. I wanted a place to tee both positive battery cables off to the starter. A piece of Delrin, a 3/8" Allen bolt, and an hour of lathe time later yielded this:
It's mounted to the front of the drivers side battery tray stand. Following that was some uninteresting and still unfinished wiring and installation of the air cleaner (which I lost the pics to somewhere ), and it was ready to drive! Yay! So, how did that go? Stay tuned to find out...
MaxPF is offline
post #23 of 49 (permalink) Old 03-07-2017, 01:38 AM Thread Starter
MaxPF's Avatar
So, the initial drive showed a few issues. Most were simple fixes of minor things, but one major problem was a random failure to crank. I had a starter relay mounted on the fender. and from that relay a 14 gauge wire snaked down to the starter along the main battery cable, a distance of perhaps 7-8 feet total. It seems this length of 14 gauge had too much resistance and gave marginal voltage at the starter solenoid terminal as well as some heating of the wire.
The immediate idea for a solution was to run a larger wire, but that meant threading a 12 or 10 gauge wire through an already-mounted loom. Instead, I close to eliminate the relay from the fender and connect the ignition switch start wire directly to the wire going to the starter. I then moved the relay to the frame rail adjacent to the starter, and used the starter wire going to the starter to instead actuate the relay. The relay switches power directly from the main battery terminal on the starter, protected with an inline fuse, to the solenoid terminal when the key is in the start position. The wire on the fuse holder is 12 gauge, while the other wire is 14 gauge. Since resistance increases with length, and the wires are kept very short with this arrangement, there have been no more failure-to-crank issues. Here's some pics before I put convolure tubing over all the wires:
I put a reverse-biased 50V Schottky diode between the starter wire and the ground wire. When the relay opens, the energy stored in the magnetic field of the solenoid has to go somewhere. Normally, it arcs across the relay terminals as they open, which will eventually cause the relay to fail. The diode allows the reverse current to travel harmlessly to ground with no arcing, where it is dissipated as heat in the solenoid winding.
Here's the installed relay and fuse:
This setup engages the solenoid without fail, even when the batteries are too weak to give more than a half-crank to the engine. The weak batteries were caused by my alternator losing a diode, which is a story for later time .
MaxPF is offline
post #24 of 49 (permalink) Old 03-07-2017, 01:41 AM Thread Starter
MaxPF's Avatar
Quite a bit has happened since the last update. I have been chasing an intermittent bump-induced driveshaft vibration for several months. Despite rebuilding the CV and replacing the output bearings in the t-case the vibration persists. I will get it figured out one of these days.
My batteries finally went Tango Uniform I was originally set on running a pair of group 24 flooded deep cycles because, frankly, I believe properly maintained QUALITY deep cycles will outlast AGMs. However, that plan got thwarted when I discovered that Sam's Club had group 34/78 Deka AGMs (labeled Duracell) for only $105 during a Christmas sale!
Sign me up on that deal! I eventualy plan on moving the batteries out of the engine bay and into the rear of the truck, so hopefully getting them out of the engine bay heat will increase their lifespan. When I do that I will make the battery boxes capable of accepting group 31's.
Not long after that my third Autozone alternator decided to windmill the pulley and spit the belt off. Swell. At this point my option was to fix the pulley and keep running the Zoner alternator, or put this in it's place:
I scored a pair of these off of Ebay for $165 each. Normally, these are $525 alternators, but these had been dropped and had broken back covers and some dings, hence the discount.
$525 you say?!?! Why so expensive? Simple answer:
This alternator can crank out 240A CONTINUOUSLY. And they are made in USA. Unlike mere mortal alternators that have six rectifier diodes that are heat-sinked to the case, these bad boys sport 12 rectifiers in their own heat sink, which is still mounted to the case for further head sinking.It also has dual fans:
I ordered new rear covers for them, as well as an 8 rib pulley and a 7 rib pulley. They 8 rib pulley is for mine, while the 7 rib pulley is destined for Todd's Jeep. These alternators have 7/8" shafts, and it seems 6 rib alternators are not made for that size shaft, so the 7 rib jobbie will be used on the LS motor with it's 6 rib belt. Here they are, ready to go:
10 hours of machining and wrenching later, I ended up with this:
What is not noticeable in the above pic is that the AC hoses and lines are gone. This was pre-planned even before the alternator debacle. I evacuated the refrigerant and capped the compressor, condenser, and receiver. In the next few days I will remove the glower/evaporator box from under the hood and the HVAC box from under the dash. This will get replaced by a unit that fits entirely under the dash. The purpose of removing the factory HVAC stuff is to make the room needed to fit the HE351VE variable geometry turbo that I have acquired Not to mention I have always disliked that crap cluttering the engine bay. It will also make room for another item I have just ordered, but I am keeping hush-hush for now
MaxPF is offline
