AMSOIL BMK23 oil filter relocation/bypass cause issues? - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 03-22-2019, 02:17 AM Thread Starter
does anyone know why the BMK23 causes "oil pressure issues" that everyone says they have? which I don't understand why they do.
I know the bmk23 comes with a "smaller" (3/4-16 instead of 1-16) full flow filter. is there a way to adapt it to run the standard cummins size filters?
I want to run a remote oil filter aswell as a bypass. but don't want to plumb the bypass into the oil cap or have to drill and tap anything. and if I could have it all in one simple mount that would be even better.
16 2500 Regular Cab Tradesman
Cummins 6.7 G56 4x4
literally my holy grail truck.
6MTCummins is offline
post #2 of 9 (permalink) Old 03-22-2019, 11:14 AM
GAmes's Avatar
iTrader Score: 7 reviews
Why not use a Fleetguard LF 9028? It spins onto the stock filter housing and incorporates a bypass element. I'm currently using them with 15,000 mile filter changes and 30,000 mile oil changes. Even at 30,000 the OA comes back as "continue use" but I change it anyway. Before you comment on it's cost, figure what the cost in actual money and hours buying and installing a bypass system would be.
GAmes is offline
post #3 of 9 (permalink) Old 03-22-2019, 11:32 AM
Moderator
9297oldram's Avatar
A bypass oil filter has a pin size hole in it that the oil enters into the filter so they can't be used for a permanent type oil filter.
9297oldram is offline
post #4 of 9 (permalink) Old 03-23-2019, 10:58 PM Thread Starter
well, the main reason is I want it to be easier to do oil changes/samples right there on the side instead of struggling in the side there. cost is not a factor here, I simply want the best. to be quite honest I planned on/wanted to run both a amsoil bypass and the LF9028. but with the BMK23 its a smaller filter thread size which was the reason for my post.
I am aware, the BMK23 is a full flow filter plus a bypass.
Cummins 6.7 G56 4x4
post #5 of 9 (permalink) Old 03-24-2019, 08:15 PM
GAmes's Avatar
Then you could do a lot better than an Amzoil product. Here's one option and there are several others.
https://letstruck.com/products/ops-e...nt=26124092995
GAmes is offline
post #6 of 9 (permalink) Old 03-25-2019, 04:05 AM Thread Starter
right, I think yall are forgetting im looking to relocate the oil filter aswell. otherwise that's something id for sure consider
Cummins 6.7 G56 4x4
post #7 of 9 (permalink) Old 03-25-2019, 08:18 AM
GAmes's Avatar
That part is easy. Since cost isn't an issue...........https://www.thoroughbreddiesel.com/p...SAAEgISPvD_BwE
GAmes is offline
post #8 of 9 (permalink) Old 04-12-2019, 07:40 PM
Millionmiles's Avatar
The Amsoil duel bypass mount is what you. No drilling, no oil cap return and not all the extra hose. The single bypass is way different.
2004 6speed 4x4
122,000
Flashpaq tuner
Millionmiles is offline
post #9 of 9 (permalink) Old 04-12-2019, 08:06 PM
*Is what you want
2004 6speed 4x4
122,000
Flashpaq tuner
Similar Threads
Warranty Issues modsixm 4th Gen Powertrain 10 11-14-2014 11:05 AM
Custom In-Cabin Air Filter For 2008 Dodge Rebel Resources 07.5 - 09 3rd Gen 6.7L Non-Powertrain 0 07-04-2014 09:27 PM
budget air filter upgrade cumminsrulez 94-98 Performance Parts Discussion 4 09-24-2013 06:46 PM
Injector Maintenance scotchwhiskey 3rd Gen. Powertrain 86 06-22-2012 09:26 PM
Royal Purple vs. Amsoil mjd91 General Diesel Discussion 8 01-30-2011 09:09 PM
