Engine blow by solution/ Engine Oil Flush - Dodge Cummins Diesel Forum
 9Likes
post #1 of 63 (permalink) Old 06-21-2018, 03:17 AM Thread Starter
CliffordBRT's Avatar
Has anyone ever used/heard of the products made by https://costeffective.com.au/2017/03...owby-problems/ ?
I am interested in trying out their Flushing Oil Concentrate as well as their FTC Decarbonizer, but I am always hesitant to pull these foreign (no pun intended) fluids into my truck. If it's not a snakeoil product, sounds like a pretty good thing to do to an engine.
Flushing Oil Concentrate: https://costeffective.com.au/product...l-concentrate/
FTC Decarbonizer: https://costeffective.com.au/product/ftc-decarbonizer/
2007 5.9L CCSB | G56 Valair DD | 5" MBRP Turbo Back Exhaust | WCFab 2nd Gen Swap | Mishimoto Intercooler | Attitude Freeze Plugs | EFI Live (EFIbyRyan) | ARP Head Studs | FASS 150| BW 63/68/.91 | Stock Injectors | Banks Monster Ram Horn | Exergy Sportsman CP3
CliffordBRT is offline
post #2 of 63 (permalink) Old 06-22-2018, 02:42 PM
BrianF's Avatar
I am hesitant on doing any flush on any engine worth anything. If you are having issues with the rings coking up, you may just want to run a cheap oil on a short change index. Maybe look at dropping the viscosity would help it without the risk of damage running some snake oil.
On a similar but different note, people would do piston soaks on older Saturn or Toyota engines that had issues with the oil control rings on the pistons. The had a tendency to coke up and cause excessive oil consumption. A trick was to pop the plugs out and using various degreasers or top engine cleaners, you would add a few ounces to each cylinder and soak it for numerous hours. Clean it out, run it and change the oil. Now this is a bit harder on a diesel as pulling the injectors to do this would not really be worth the hassle unless you exhausted other options.
2017 Ram 3500 Megacab, SLT, True Blue, SRW, CTD, AS69RC. Ubique
BrianF is offline
The Following User Says Thank You to BrianF For This Useful Post:
Grogg (06-26-2018)
post #3 of 63 (permalink) Old 07-04-2018, 10:27 PM
9297oldram's Avatar
I bought a gas v8 that used oil and smoked real bad, put some Marvel Mystery oil in it and drove it for a few miles and changed the oil and it freed up the rings and didn't have anymore problems.
Not sure it would help your problem but might be worth a try.
9297oldram is offline
post #4 of 63 (permalink) Old 07-05-2018, 01:20 PM
KATOOM's Avatar
What are you trying to solve? I would be very hesitant using any product with tempting promises. If you're experiencing excessive blowby, have you tried a compression test, or checked the injectors?
KATOOM is offline
post #5 of 63 (permalink) Old 07-05-2018, 06:00 PM
Grogg's Avatar
Your motor oil constantly cleans the engine as long as you don't run it past condemnation point (or manufacturer intervals, in lieu of analyzing oil).
If you really want to clean your engine, run a few short oil change intervals with an appropriately rated oil (CI-4, CES20078, whatever applies to your particular motor)
2006 RAM 3500 DRW 6 speed 4WD QCLB: unit bearing delete, metric delete, all tow no go.
1991 W350 SRW auto 4WD RCLB: Fleetjunk delete, Garmon trans, NASTRUCK
Just say no to metric Daimler-Fiat
Grogg is offline
post #6 of 63 (permalink) Old 07-13-2018, 09:49 AM
TECH SPECIALIST
steve05ram360's Avatar
Hot shots stiction remover... 2 oil changes back,, used 4qts in 7k miles, added the HSSR, this oil change 1/2-1 qt used over 10k. Alarmed by the 4qt loss, i kept a close eye on it this last 10k. Shocked to see it drop so much. Researched it some and believe i had stuck rings.
The HSSR is not cheap at $30/qt, but cheaper than an engine rebuild.
utahtrapper likes this.
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 428k, HPTuners, G56, 25.065 mpg, mpg threads ->https://www.cumminsforum.com/forum/3...l#post23312562
steve05ram360 is offline
post #7 of 63 (permalink) Old 07-25-2018, 12:49 PM
Steve did you follow the guidelines for the HSSR for the first time you used it? I know it says for the initial dose to use 2qt for initial and then 1qt for maintenance...I did half the rec. dosage
also, do you still use the powermaxx products? I have been using them since I bought the truck over a year ago...not sure if the commonrail fuel cleaner/oil cleaner did anything, thats why I tried the HSSR in with this oil change...I am trying a few diff. things cause I think my injectors may be on their way out, when I get the RPMs up and let off, they're choppy on the way down...most are saying the injectors are leaking/hanging so before I pull them and/or test them Im trying some other things first...no other symptoms of injector failure thank god
2005 2500 SLT Auto QuadCab 180k Mostly Stock 4" straight pipe 34" Terra Grapplers
thaemcee2 is offline
post #8 of 63 (permalink) Old 07-26-2018, 01:35 AM
TECH SPECIALIST
Yeah used the powermaxx.... did not notice anything with it. It was not in the motor long per instructions... the HSSR (1 QT) was in there the entire 10k and did appear to have an effect. Previous OCI I lost 4 qts of oil in 7000 miles, after that, less than 1 qt after 10k. That trend is continuing now on the 2nd oil change after that HSSR install.
If your at the point of yanking the injectors... give ATF a try. I use the ATF/2SO mix these days. Get the Supertech Dex III/Mercron ATF and 2SO if you do. Do 16oz of ATF & 24oz of 2SO to a full tank and run the tank down before filling back up. You may see a change in ~300-400 miles if it is helping.
To add... after the HSSR & the HS FR3, motor runs awesome. Happy with it and one would never know its got over 370k on it. I contacted HS and asked about using a 50/50 mix of the HSSR & FR3 and they say its not needed to mix them but no problem if I do. I am planning to do that mix on the next OCI and all of them moving forward as a maintenance additive. Needed or not, still gonna do it.
post #9 of 63 (permalink) Old 08-10-2018, 07:57 AM
IH8CALI's Avatar
Getting ready to do a healthy dose of ATF/2SO today followed by a complete round of HSSR. I will post results here rather than start a new thread (Seems to be the most current thread we have going on the topic). Thank you Steve for all for the great information regarding the various forms and personal results of supplementation!
Working on my next broken heart.
(Sold) 04.5 3500 SRW HO 6spd I want her back! VIN: 3D7LU38C24G196788
(Sold) 06, 02, 99, 93
IH8CALI is offline
post #10 of 63 (permalink) Old 12-09-2019, 11:35 PM
dbow20's Avatar
Just wondering what your results were after using the ATF and HSSR. I’m considering doing the same but would like to hear more about results.
2014 CCSB 2500 Laramie Longhorn
Sold-2003 Quad Cab, 48re, Second Gen64/68/13, BMS 100%, ARP 625s, Hamilton 188/220
dbow20 is offline
post #11 of 63 (permalink) Old 12-10-2019, 10:52 AM
GAmes's Avatar
iTrader Score: 7 reviews
Originally Posted by dbow20 View Post
Just wondering what your results were after using the ATF and HSSR. Iím considering doing the same but would like to hear more about results.
I don't understand why anyone would pour ATF into the fuel and expect good results, especially a close tolerance, high pressure system. Have you ever looked at what the additive package is in the product that is formulated for TRANSMISSIONS? The best thing you can do to increase your fuel system life is use the best filters you can find.
97 3500, 2 WD, G56, slightly bombed, 1.3 million miles with un-additized diesel fuel. Started the second million on 8/24/13
GAmes is offline
post #12 of 63 (permalink) Old 12-10-2019, 12:40 PM
TECH SPECIALIST
GAmes here is a data sheet for the Dex III ATF, tell me whats in there that is an issue...? I use the Supertech Dex III/Mercron in mine, when I use it regularly, never an issue. When I'm not using it and not beating on it, performance starts to drop off. Drop in the ATF mix (includes the 2SO) and performance comes back.. My truck is a daily driver, 300~500/week, no towing or hauling. I have ~100k on my current set of injectors.
Educate me please...
https://marketing.transtar1.com/acto...MVDEX3-EXP.pdf
https://marketing.transtar1.com/acto...data_sheet.pdf
