Shell Rimula oil any good? - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 05-22-2018, 10:15 PM Thread Starter
2017 5500, 13500 miles. Getting ready for 2nd oil change. I'm doing around 5-6k. I haul/deliver sheds. Loads can be on the heavy side plus lots of wind resistance. Good but if idle time when setting a shed. First oil change was Rotella 15w-40. Just wondering if anyone had anything to say about the Rimula Super 15w-40. Not going synthetic due to frequent oil changes although I like it more. I know everyone has their preferences. I can get the Rimula ($520)a little cheaper than Rotella or Delvac ($600 ish)
2017 Ram 5500 4x4, Aisin 6 spd, 4.44 axle, 60" c/a, EBY alum flatbed.
ASH67 is offline
post #2 of 6 (permalink) Old 05-23-2018, 01:06 AM
BrianF's Avatar
Shell makes great products. If it carries CJ-4 or CK-4 and ,CES20081(86) then run it.
There is nothing wrong with running a conventional oil as opposed to a synthetic unless your climate dictates.
2017 Ram 3500 Megacab, SLT, True Blue, SRW, CTD, AS69RC. Ubique
BrianF is offline
post #3 of 6 (permalink) Old 05-23-2018, 11:32 AM
RammerJam's Avatar
My understanding is that 'Rimula' is just their overseas line but is similar in every other regard including names like T5, T6
P.S.
As an aside, I'm not crazy about changing your oil too often. I've read reports that changing it too often is almost as bad as not enough. I'm not buying that part but I don't think it's all that good for the engine
From what I read, the detergents, additives, etc, in new oil are rather harsh and the oil actually does a better job after most of the detergent additives have left the room.
I think following the Company's guidelines is a good place to start. If you wanna go just a little more often, good on you. But too much is too much, IMHO
2017 4X4 SLT Ram Big Horn 2500 SB Cummins
RammerJam is offline
post #4 of 6 (permalink) Old 05-23-2018, 06:16 PM
P.S.
Changing your oil too often is just a waste of money, but no way is it bad for an engine. I change mine every 7500 miles, which is about every six months, which just happens to be what ram recommends.
2015 2500 Laramie ccsb CTD, Lots of thuren goodies, fox shox, bmf novakanes, amp steps, lost a few parts underneath, and the list goes on......
Mmecsics is offline
post #5 of 6 (permalink) Old 05-28-2018, 07:42 AM
vreihen's Avatar
Blackstone lab report is the answer. What was the question?????
2006 Ram 2500 SLT QCSB, 4x4, 6-speed G56 manual, VDO blower motor upgrade, panic button and recirc door delete mods, Diamond Eye 4" stainless cat-back exhaust, Tuson DirecLink OBD-II trailer brake controller,
, #MirrorsDown
vreihen is offline
The Following User Says Thank You to vreihen For This Useful Post:
Grogg (05-29-2018)
post #6 of 6 (permalink) Old 05-29-2018, 02:04 PM
Grogg's Avatar
P.S.
You're on the right track. As motor oils are exposed to temperature and oxidization, there are molecules which form anti wear layers at various temperatures. These films are less active in new motor oil, where only some cultures of them exist. Essentially, wear is a parabolic curve.
https://www.sae.org/publications/tec.../2007-01-4133/
https://www.bobistheoilguy.com/used-...hat-is-normal/
Changing oil too often is definitely a waste of money, however it appears that changing too often could actually incur excess wear of your engine's metal parts (which some might think is bad)
2006 RAM 3500 DRW 6 speed 4WD QCLB: unit bearing delete, metric delete, all tow no go.
1991 W350 SRW auto 4WD RCLB: Fleetjunk delete, Garmon trans, NASTRUCK
Just say no to metric Daimler-Fiat
Grogg is offline
