Front Disk Brake Pad Replacement's - Page 2 - Dodge Cummins Diesel Forum
98.5-02 Repairs/Replacements This section is for helping you know what to do when something breaks. How to replace things, repair them, etc...
post #13 of 21 (permalink) Old 03-10-2006, 08:42 PM
Guest
Guest
Posts: n/a
I dont think a pint would be enough for a total change out, wouldnt be much more than that though.
I just did the rear brake upgrade, after the new cylenders went in I blead everything down till the master cly was almost empty then toped it off with new fluid, it was really amazing to me how dark the fluid was that I blead off
post #14 of 21 (permalink) Old 03-10-2006, 08:57 PM
Monster Truck's Avatar
Your supposed to bleed it till you get clean fluid.
94 Single Cab Custom Flat bed, Loaded, Auto,3.55s, straight 3.5'' pipe, custom fuel plate AFC all the way forward, Intake, 250k, New build lots to be done.
Monster Truck is offline
post #15 of 21 (permalink) Old 03-10-2006, 09:06 PM
2001shrtbedcummins
Guest
Posts: n/a
yea I didn't know that
post #16 of 21 (permalink) Old 03-10-2006, 09:09 PM
Guest
Guest
Posts: n/a
It did.....came way clean
post #17 of 21 (permalink) Old 03-10-2006, 09:36 PM
Originally Posted by LinemanTater
I'm having the front brakes done next week, Whitmore do you know how much fluid I should buy to do the front brakes???
One quart has always been more than enough for me. I usually suck all the old fluid out of the master and refill with new before starting bleeding.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #18 of 21 (permalink) Old 03-11-2006, 02:33 AM
LinemanTater's Avatar
Thanks guys, just figured while he's in there doing the front brakes he might as well replace the fluid also:thumbsup
2013, 2500 Megacab Laramie G56 (Manual 6spd) 4wd, PPEI EFI Live.
2007 5.9 mega Dually
1998 24v
LinemanTater is offline
post #19 of 21 (permalink) Old 03-11-2006, 09:53 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
Be aware guys...
On the 2002 edition we have the large reservoir on our brake system. I forgot how much it holds... But by the time time I got done bleeding down the system and refilling I was passed the 1 quart bottle... But not by much...
I've seen on several other years of trucks a much smaller reservoir that you could change out with just a quart and have plenty!
Mopar1973Man is offline
post #20 of 21 (permalink) Old 03-11-2006, 10:19 AM
Mopar1973Man.Com
Oh BTW...
Another Brake fluid reservoir that we all forget about is the clutch. Now take notice that it never seems to darken and never seems to lose fluid. Why is that???
Answer is easy..
1. The system is complete made of plastics. There is no steel plumbing in this system. So if the fluid has moisture in it there is nothing to attack or oxidize.
2. Clutch system doesn't show wear like the brakes do. In other words as your brake pads wear the piston move outward and you'll start to see a drop in brake fluid to take up the slack.
But you might just keep a watchful eye on that little reservoir. If you really feeling good you might even change it while your doing the brake system. But remember there is NO BLEED screws on the clutch system so don't get any air in it. Just drain the reservoir and refill...
post #21 of 21 (permalink) Old 03-11-2006, 05:42 PM
good point...often overlooked..
Cepp is offline
