Do not use the nv4500 nut retainer from 5th gear repair!junk - Dodge Cummins Diesel Forum
post #1 of 28 (permalink) Old 09-09-2013, 02:54 AM Thread Starter
miller69time's Avatar
Do not use the nv4500 nut retainer from 5th gear...
first im not gona sugar coat things here,I hotshot for a living so i tow heavy usually 20k to 26k lbs and i run @ 275hp nothing crazy. ive been through 5 nv4500 reman transmissions so far in about 120k miles. One thing i can tell u is nothing lasts forever and bullitproof is a lie but i cannot get a nv4500 past 30k miles and its always fifth gear eather it brakes the teeth off the gears or sheeres the splines off the full spline mainshaft or the little gear just explodes. all im asking for is atleast 100k .Now some may ask why do u,tow in 5th well this is why my truck in a 4:10 truck with 235 85 16s so anything above 50 mph,it,has to be in 5th. Anyway i wanted to share my last failure with you,guys i used the 5th,gear nut retainer sold by 5th gear repair .com i used a standard locknut and washer due to not,enough room for the split washer i usually run. Not even 15k on this thing and it took out my transfer case it pushed so hard on the transfer case input shaft it broke the snap,ring then pushed it back destroying the low lock shift fork assembly. Oh ya the nut retainer broke all 4 little tabs off and then the nut backed off.i never fully lost 5th though just horrible grinding out of the t case. Now the trasfer case needs rebuilt and im kinda done with the nv4500 unless someone comes out with a real fix for these things.Mainly the 4:10 and heavy towing are the cause of all this. Hopfully something will hold together.
miller69time is offline
post #2 of 28 (permalink) Old 09-09-2013, 01:27 PM Thread Starter
I dont understand what happened to my posting but here it is again i ran it for approx 15k it broke all four little tabs then the nut came loose putting extreme pressure on the input shaft of my np241dhd transfer case braking the front snap ring to the input shaft then it pushed the input shaft of the t case into the four low lock shift fork destroying that. Now t case needs rebuilt. Not impressed
1998 1/2 3500 4x4 quad cab sport
post #3 of 28 (permalink) Old 09-09-2013, 01:29 PM
Rescue Tower
Shainer's Avatar
Forum has issues right now. You talking about these guys?
NV4500 Transmission 5th Gear Repair
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
post #4 of 28 (permalink) Old 09-09-2013, 01:33 PM Thread Starter
Yep exactly ive seen them on ebay also.not a good fix at all caused more harm than good..not happy at all right now
post #5 of 28 (permalink) Old 09-09-2013, 02:04 PM
Rescue Tower
Shainer's Avatar
They are in my back yard. Have you spoke to them about it? I don't know anybody using that fix so I'm not sure what their failure rates are.
Shainer is offline
post #6 of 28 (permalink) Old 09-09-2013, 03:14 PM Thread Starter
I called them today they only heard of this happening one other time. the guy who made the nut retainer is supposed to call me later hopfully they will get back with me.
post #7 of 28 (permalink) Old 09-09-2013, 03:28 PM
KATOOM's Avatar
I'm interested to see what you find out or where this goes, because awhile back when this new "fix" was circulating around the forums, I was skeptical based on two things. 1) Its only designed to work on 4wd truck. And 2) because of reason number 1, that means that it used the T-case as support against the new retainer so as to stop it from being able to back away. That seems to weird to me since logic would tell ya that transmitting the load from one component to another component, asking that second component to bear more load than it was designed for isn't going to solve any issues.....but place more stress on the second component, and therefor cause other unforeseen issues. I may be wrong, and I remember how this company was praised too for their brand new concept and how affective it supposedly works. But.....I've ONLY ever heard that the CORRECT fix is to replace the whole shaft with a new fully splined shaft. Even at that, you still have a gear that hangs out being supported by one side. Not necessarily a problem.....until you put a huge low RPM torque Cummins in front of it.
KATOOM is offline
post #8 of 28 (permalink) Old 09-09-2013, 03:48 PM
GKsHOCUMMINS's Avatar
So that goes around the stock nut? Interesting... Have you tried the "updated" nut? These are what we would install at the shop I used to work at when the stocker backed off. I also used plenty of loctite and made sure it was nice and tight. I only saw one come back and that was because the guy at our shop who installed it didn't put loctite on it.
01 HO 6spd/4wd/AMSOIL BHAF/BD track bar,steering brace/09 Steering/Short Shifter/ConOFE/FASS/ARP Head Studs/Blue Chip VP44/JUICE w/ATTITUDE/Aurora 3000/Snow WaterMeth/5" MBRP/AMSOILED/AutoMeter Guages/onboard air/Leveled/SpynTec Hubs/33" Toyo HTs
GKsHOCUMMINS is offline
post #9 of 28 (permalink) Old 09-09-2013, 08:33 PM
Rescue Tower
Shainer's Avatar
I've seen this become a more common repair say 1 - 1.5 years ago. While I say more common I mean guys started talking about them etc. I have yet to know anybody personally running one. Hopefully they can/will provide some meaningful insight/causation and how to prevent it. Doubt they will do anything for the additional damage. Which sucks but on the other hand if their parts were not on there the worst that would happen is the nut and gear fall to the back of the shaft.
Shainer is offline
post #10 of 28 (permalink) Old 09-09-2013, 09:19 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
I have no idea what nut is in my truck but I'm hear to say that not all trucks had the 5th gear nut issue. I'm at 221k miles and hauled or towed heavy the entire life of this truck and even climbing steep mountain grades as steep as 16% without a single issue. I've got several theories on what causes 5th gear nut issues.
Mopar1973Man is offline
post #11 of 28 (permalink) Old 09-09-2013, 09:44 PM
I have a diesel problem..
tdanielson95's Avatar
iTrader Score: 6 reviews
Mine just came in today I hope for $145 they replace it...
2013 GMC 2500 LML Duramax. ECSB. Anarchy EFI, 4"
2001 Dodge 2500 ECSB Sport, 24v, Nv5600, Valair DD, 62/68/14, 100hp injectors, Smarty MM3
2003 Jetta TDI, 5 speed swap, DLC1019 injectors, VNT17 Turbo, 3 Bar MAP, Malone stage 4 tune, Southbend SMF clutch, 3" TBE, EGR delete, 2" IC pipe, EGT and Boost gauges, OMI, VAG-COM.
Sold: (Cummins, of course) 12, 06, 03, 01, 01, 99, 97, 95, 94.
tdanielson95 is offline
post #12 of 28 (permalink) Old 09-10-2013, 10:41 AM
KATOOM's Avatar
So do I. I've tried to narrow some of my "theories" down too, but getting anyone to describe their driving habits, or remember when and how their 5th gear issue happened, has proven unsuccessful.
KATOOM is offline
