Smoked Lost Power then started working - Dodge Cummins Diesel Forum
 3Likes
  • 1 Post By bigfish95971
  • 2 Post By bigfish95971
post #1 of 11 (permalink) Old 02-12-2020, 04:48 PM Thread Starter
Last week I was traveling down I-5 with my RAM 2001 and Lance Camper. About 60 miles into the trip suddenly I lost all power and lots of black smoke from the tail pipe. I pulled over and had no power but lots of black smoke. I tried to keep it running but it finally died. When I restarted the truck everything worked fine. Plenty of power and no smoke, worked great for the last 60 miles of the trip.
No codes thrown.
It is stock except for and exhaust brake. Anyone have any ideas? I am afraid to drive it until I can fix the problem.
Thanks
Allen13331 is offline
post #2 of 11 (permalink) Old 02-12-2020, 09:07 PM
KATOOM's Avatar
Do a once over on all major electrical cables, grounds, and connections and batteries just to rule out something obvious. But it almost sounds like your MAP or CPS sensor is faulty.
KATOOM is online now
post #3 of 11 (permalink) Old 02-13-2020, 12:37 AM
What throttle conditions were you doing when it happened? What did the voltmeter do when an after it happened?
bigfish95971 is online now
post #4 of 11 (permalink) Old 02-14-2020, 08:26 PM Thread Starter
Throttle
Throttle position....I was on I5 doing about 65 just cruising. No heavy acceleration, might have even had cruise control on.
I am really stumped.
post #5 of 11 (permalink) Old 02-14-2020, 09:02 PM
No codes an fuel issues, no acceleration so no boost issue unless a turbo bearing stopped for a bit. I would suspect I would suspect a temporary or precursor electrical issue. Check all battery terminals and cables for loose, o corrosion and clean perfectly. Take off alternator and have load tested and tested for ACv. The one time mine did that the alternator was toast but it did work just a little bit after cooling off. It restarted and ran on batteries though. Could also have been a wiring or sensor issue, IAT, MAP Cam etc. May be a temporary seizure of the timing piston in the VP44, if so it will likely come back.
post #6 of 11 (permalink) Old 02-15-2020, 03:47 PM Thread Starter
It has been running fine since that one episode. I don’t know what to make of it. I guess I will drive it until it the problem becomes more of an issue. It only has 86K miles so it should have a few good miles in it.
post #7 of 11 (permalink) Old 02-15-2020, 07:24 PM
Regardless, you should clean up and check all electronics including AC check and pull and clear codes.
Clunk likes this.
post #8 of 11 (permalink) Old 02-16-2020, 07:58 PM Thread Starter
Thanks, I will do so.
post #9 of 11 (permalink) Old 02-16-2020, 08:02 PM
Clunk's Avatar
Originally Posted by bigfish95971 View Post
unless a turbo bearing stopped for a bit. .
Mine poured black smoke when the used turbo locked up....never freed up though.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
post #10 of 11 (permalink) Old 02-17-2020, 12:25 PM Thread Starter
Clunk
That is what I am leaning toward. Just hope it does not do it again on I5 in Portland like last time. I had a lot of middle finger salutes directed at me.
post #11 of 11 (permalink) Old 02-17-2020, 12:34 PM
`Pull intake hose and check turbo for free spin and oil in side it.
Clunk and Allen13331 like this.
