Bad vibration and oil leak - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 10-19-2019, 06:08 PM Thread Starter
Beansko's Avatar
Just started having a bad engine vibration and oil leak. I can’t pinpoint where the leak is coming from but it seems like it’s on the front left of the engine. Its quite a good amount of oil but only leaks badly when it’s running. The vibration calms down slightly when I apply the throttle. Can anyone tell me what the problem may be?
2002 2500 HO 6 spd
FASS 150
BHAF
Beansko is offline
post #2 of 18 (permalink) Old 10-19-2019, 09:02 PM
afterburn549's Avatar
Would you like me to wash it dwn and sprinkle some baby powder on it and take it for a ride?
98.5 1 ton Dually -Engine balanced, 275 HP Inj. Ceramic topped pistons with Molly skirts
Mercedes 6 speed, air bags on rear.
Gauges, steel piston squirters
afterburn549 is offline
post #3 of 18 (permalink) Old 10-19-2019, 09:18 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
Front left is generally vacuum pump/power steering pump seal.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #4 of 18 (permalink) Old 10-19-2019, 10:49 PM
Could also be the tappet cover. You probably should do them both anyways.
Massuh_Nate is offline
post #5 of 18 (permalink) Old 10-19-2019, 11:50 PM
KATOOM's Avatar
When the engine is idling, see if the harmonic damper is wiggling.
KATOOM is offline
post #6 of 18 (permalink) Old 10-21-2019, 06:24 PM Thread Starter
Beansko's Avatar
Well I was waaaay off. Hit it with degreaser and the pressure washer. Couldn’t find the leak. Crawled under the front end and traced it back to a 3” hole in the right side of the block. Looks like it was thrown rod which surprised me because I didn’t think it would still run with a thrown rod.
2002 2500 HO 6 spd
FASS 150
BHAF
Beansko is offline
post #7 of 18 (permalink) Old 10-21-2019, 08:23 PM
On call 24/7
Wow! Not the first cummins ive heard of that still runs with the hole in the block. Where you at in Texas?
post #8 of 18 (permalink) Old 10-21-2019, 09:45 PM Thread Starter
Beansko's Avatar
Yeah I don’t know what could blow a hole in a block like that where it could still run. A thrown rod should make a lot more racket and it wouldn’t run right? But other than the rough idle and oil leak there’s not any other issues. The hole in the block is about 2 1/2-3 inches. Is it possible to weld a patch on a hole that size? I’m in the San Antonio area.
2002 2500 HO 6 spd
FASS 150
BHAF
Beansko is offline
post #9 of 18 (permalink) Old 10-22-2019, 10:59 AM
On call 24/7
No, a new block is in order.
post #10 of 18 (permalink) Old 10-22-2019, 12:36 PM
poriggity's Avatar
Definetly no fixing that. It will need to be replaced.
2004.5 2500 Quad Cab with some Carli and Thuren stuff.
poriggity is offline
post #11 of 18 (permalink) Old 10-22-2019, 03:48 PM Thread Starter
Beansko's Avatar
Nice. Time to start calling the junkyards around town then.
2002 2500 HO 6 spd
FASS 150
BHAF
Beansko is offline
post #12 of 18 (permalink) Old 10-22-2019, 04:34 PM
On call 24/7
https://dallas.craigslist.org/ftw/pt...997377581.html
Pretty good price if it actually runs good.
