Hope it’s not the VP44 - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 10-12-2019, 12:11 AM Thread Starter
2001 ram 2500
Today at work my truck would not start. It had been shut off for 15 min. I tried again about 2 hours later and still nothing. My fuel gauge was reading 15 psi. I depressed the schrader at the vp44 and got a good spray of fuel out. For lack of any better thoughts I gave it a shot of starting fluid and that got it running. I drove home from there after about 20 minutes of mixed highway and town driving it started to sputter while going 50mph. I kept my foot in it until someone pulled off the road in front of me. As soon as I let off the throttle it died flat while going about 25mph. I pulled off and after 3 rounds of ether she was running again. I kept my foot in it the rest of the way home(ending with a long steep grade). I shut it down and started it back up fine. Several hours later it is still starting fine. The fuel pressure did not drop below 8psi the whole trip. There are no trouble codes. I am looking for suggestions as to what I might look at. I changed the fuel filter after this just because it was due.
Meacez is offline
post #2 of 9 (permalink) Old 10-12-2019, 01:49 AM
Obviously you need to start with pulling codes with a scan tool, rather than the key. If you get one of the three codes for a bad VP, they are usually correct.
bigfish95971 is online now
post #3 of 9 (permalink) Old 10-12-2019, 12:31 PM Thread Starter
Thank you for the reply. I did not specify that I did use a scan tool to pull the codes. Sorry about that. I think that I have it narrowed down to sucking air somewhere low in the fuel tank.
Meacez is offline
post #4 of 9 (permalink) Old 10-12-2019, 12:37 PM Thread Starter
Possibly the sock came off of the pickup or has a hole in it.
Meacez is offline
post #5 of 9 (permalink) Old 10-13-2019, 03:30 PM
What "sock" Do you have an aftermarket draw straw? How much fuel is in tank? What lift pump and draw system? Air leaks in intake side of fuel system are rear but possible, usually on systems that have had the tank out, or original systems that have a damaged fuel module from old and wear and tear. Having to "keep you foot in it" is usually VP related. Sometimes VP's go out overtime and do not always throw codes immediately. Keep checking.
Make sure you check all battery terminals and harness plugs for loose, dirt or corrosion.
post #6 of 9 (permalink) Old 10-13-2019, 04:15 PM Thread Starter
I assumed that the draw straw has a sock on the end of it to prevent any potential large chunks from getting into the lift pump/ help prevent air from being drawn when the tank is low and sloshes. When the problem started I was sitting at 1/8 of a tank. Since I filled the tank I have had no more issues. I have the Factory lift pump in the engine bay. It keeps good pressure and I have a fuel pressure gauge on my A pillar that I monitor so I am good with it. The truck is at 255,000 miles and I have owned it since 185,000. In that time there have been no issues with the fuel system. I have not opened the system up at all other than to change fuel filters.
Meacez is offline
post #7 of 9 (permalink) Old 10-13-2019, 07:32 PM
There is no "Draw Straw" on the stock system. It is contained inside fuel canister module. But you are probably right in general. Original modules have some screens and one way valves in them that get old and damaged allowing the canister reserve for steep hills and turns and stopping to loose its fuel so that when low on fuel it all goes to the front of the tank and sucks air, killing it and often needing bleeding to get going. We call it the "1/4 tank problem". If the case, the answer is module replacement or keeping it fuller, over 1/4 tank full.
However this is not a problem going donw the straight road crusing. Only on steep hills, hard sharp turns or sharp stopping.
post #8 of 9 (permalink) Old 10-13-2019, 08:34 PM Thread Starter
I did some searching and did not see any baskets available that did not have a fuel pump in them. Is that product out there and I am just not finding it? Is it best to just go to a draw straw or sump at this point if i plan on using my entire fuel tank? Thank you very much!
Meacez is offline
post #9 of 9 (permalink) Old 10-14-2019, 04:40 AM
There may be some aftermarket now or substitutes. But there did not used to be. The reason they all have the fuel pump is because that is for the in tank pump conversion. It was don becasue of repeated failure of original on block lift pumps due to wear from diesel engine vibration. If they were available they would be about the same price.
Google may help.
Look under an 02 on Rock Auto for the one youa re seeing or conversion. They range from brands 99 to 400 bucks.
