Normal temperature gage range? - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By 98whitelightnin
post #1 of 11 (permalink) Old 09-29-2019, 09:47 AM Thread Starter
Hi all,
I was wondering what would be normal behaviour for the temperature gage on a 2001 cummins 24 valve. The needle goes one or two width of the needle over the 190 degree mark on the first or first few cycles of the thermostat before the engine is completely warmed up. Or is it just that the temperature sensor is located in some area that gets more fluctuation in coolant temperature and Dodge didn't bother making the temp gage not show any readings that would cause paranoia in me? Or do I need a new thermostat? 190 would be normal temperature since I live in a cold climate.
2001 Dodge Ram 2500 4x4 Cummins + NV4500/NP241
Luoppis is offline
post #2 of 11 (permalink) Old 09-29-2019, 11:47 AM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
Sounds normal to me. The sensor is on the front of the head and it will stay pretty stead on the gauge because dodge didnt want you to worry about it moving. I ran a mechanical gauge on my 98 and it stayed pretty steady.
Clunk likes this.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #3 of 11 (permalink) Old 09-29-2019, 07:27 PM
chadmac's Avatar
My gauge gives me about a 10 degree swing and I consider that normal so yours might be more normal (better) than mine.
Translation: you're good.
02 2500 4X4, reg cab shorty, 3.55, Smarty/TST, 75 over 62, 150 inj, 5" exh, 12" lift on 20" 34's, Goerend billet triple disc auto, Yukon hub/bearing kit
chadmac is offline
post #4 of 11 (permalink) Old 09-30-2019, 12:08 AM
That is normal, but make sure the radiator is full of coolant as air will not register on the sensor well. Warm up with cap off and keep filling and then keep coolant in the overflow at proper level. If coolant is rusty run Prestone 3 day flush and change.
bigfish95971 is online now
post #5 of 11 (permalink) Old 09-30-2019, 07:48 PM
I disagree. Cummins and NAPA thermostats hold rock solid in the center of the gauge. Aftermarket thermostats I've bought have fluctuated above and below the center mark. My 00 never drops once it's warmed up unless I turn the engine off and let it cool. This is in mild TN winters but it never goes to the hot side in 95+ summer temps either.
Periodically flush your coolant to avoid electrolysis eating your radiator and more importantly heater core. Measure voltage of the coolant (so says heater core manufacturer) and anything approaching .3V needs changing.
2000 LWB, Quad Cab, 4x4, NV4500, AirDog, Gauges, Thuren Track Bar, Lost crappy AGR and A1-Cardone steering boxes. RedHead is the best so far but truck has stopped returning to center. Hopefully, I'll get to it soon.
Junkman is offline
post #6 of 11 (permalink) Old 09-30-2019, 09:26 PM
Sometimes they will drop for just a bit after first opening. I have also seen the heater use drop it slightly below that 190 mark. But you are right under normal down the road conditions they should hold pretty steady if full of coolant with no air in it.
post #7 of 11 (permalink) Old 10-03-2019, 02:32 PM Thread Starter
Thanks for all the info. I'm sure there is no air in the system and no leaks what so ever. Coolant is clean and the previous owner changed it under 2 years ago when he changed the water pump. I do have a spare gates thermostat at hand though and replacing it doesent seem like a tough ordeal unless somebody went and used RTV on the thermostat housing. I wish I had some kind of ODB2 thingy to read what the computer thinks what the exact engine temperature is.
Luoppis is offline
post #8 of 11 (permalink) Old 10-04-2019, 02:23 AM
Thermostat housing uses no gasket or RTV. The thermostat has a grooved rubber gasket that fits around the thermostat that seals both sides. If it is missing coolant can flow around the thermostat. Fix with correct seal on it. They may be available separately. Remember the thermostat is slightly larger diameter that those in the V-8's. Some parts guys give the wrong one. Whenever you buy one listed for Cummins it should have the seal with it. Do not use RTV or gasket.
post #9 of 11 (permalink) Old 10-14-2019, 02:04 PM Thread Starter
I changed the thermostat 8 days ago. No RTV on the housing, just popped the old t-stat out and carefully put the new one in with the supplied seal. The result is that the needle range shifted down a bit. It no longer goes above 190F and is maybe a bit more stable. I'm not 100% satisfied with the new thermostat though since it's supposed to be a 190F but it opens before the needle reaches the 190 line. I've read on other sources that it's pretty normal for these engines to have a bit of temperature fluctuation in this kind of cold climate as there is so much cold coolant in the radiator that it is inevitable that the coolant temperature will go down quite a bit when the thermostat opens. But we are still talking about a few degrees, not like throwing a ton of ice on the engine. This thing is pretty invulnerable to any form of winter front too.
So as chadmac said I'm good. But I also want to make sure that I got a properly working thermostat at the same time.
Luoppis is offline
post #10 of 11 (permalink) Old 10-15-2019, 02:56 AM
Stop worrying and drive it. There will be times when the heater core and little vent holes in the thermostat it will drop a bit, or even take a minute to close the thermostat.
post #11 of 11 (permalink) Old 10-15-2019, 05:10 AM
It sounds like it is working fine. As others have said, just drive it and enjoy, until the next part needs tlc.
02sedona is offline
