Brand new 47re hanging on to first - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By Dynamic
post #1 of 8 (permalink) Old 08-15-2019, 01:13 AM Thread Starter
01maroon's Avatar
I just put in a brand new unit from a highly rated transmission company and I am having an issue. Under normal driving throttle inputs the transmission is holding on to first gear for what seems like way too long. It is shifting at about 2500rpm and then slamming very hard into second. Second on up are firm, but shift in normal spots. This makes it terrible to drive in daily conditions. What could be the issue?
2001 qcsb 4x4, Revmax Trans, Edge EZ, 2" Level, 20" Monsters,Isspro EV2 FP Gauge, FRRP, BHAF, Timbo apps
01maroon is offline
post #2 of 8 (permalink) Old 08-15-2019, 02:29 AM
Sounds like maybe they put a bad or cheap governor pressure sensor in it. Any which way it sounds like a warranty issue you should call them over.
bigfish95971 is offline
post #3 of 8 (permalink) Old 08-15-2019, 06:50 AM
Stormin08's Avatar
are you certain the TV cable is adjuated properly ????
is has been said, some trans builders like a WOT shift to be about 2800rpm.
02 Sport / 47re / 4" MBRP TBE / DAP 75hp sticks/ HX35W / GDP FUEL BOSS / DDRP02 / 3rd gen brakes / 4th gen steering / 2" Thuren / MC ARMS / 5100's /285/75/17
Stormin08 is offline
The Following User Says Thank You to Stormin08 For This Useful Post:
01maroon (08-20-2019)
post #4 of 8 (permalink) Old 08-20-2019, 12:25 PM Thread Starter
01maroon's Avatar
Thanks Stormin08 I looked into the TV cable and that did the trick, for the most part. It now shifts at normal RPM still quite firm and jerks your head back, but I think thats just a built tranny for ya
01maroon is offline
post #5 of 8 (permalink) Old 08-20-2019, 03:32 PM
magnum12r's Avatar
Most newly rebuilt trans' will have a pretty firm shift at first (from experience with older gas engine trans') but usually smooth out over time as they break in, I don't have any experience with built diesel transmissions besides riding in my buddies 3rd gen with a built 48, it seems like it has smoothed out a bit since he first had it installed. If I'm wrong somebody please correct me so I learn
Sent from my SM-N950U using Tapatalk
magnum12r is offline
post #6 of 8 (permalink) Old 08-20-2019, 09:30 PM
Dynamic's Avatar
Have you called the "highly rated transmission company" to get their advice on setting up the TV cable? Did they send any instructions or any pressure test regimen?
Russ Roth likes this.
2000 Ram 2500, Quad, SB, 4x4, 24V...SOLD
Dynamic is offline
post #7 of 8 (permalink) Old 09-09-2019, 05:30 PM Thread Starter
01maroon's Avatar
I did, and they did not provide either of those. That is why I turned to posting up a thread here.
01maroon is offline
post #8 of 8 (permalink) Old 09-09-2019, 06:34 PM
custom user title
thepureface's Avatar
I think you should name the highly rated trans shop for us
2000 4x4
Built Auto
phatshaft 62 over s475
DOR steering+suspension
P pump swapped
thepureface is offline
