24V Killer Dowel Pin - Dodge Cummins Diesel Forum
 1Likes
post #1 of 13 (permalink) Old 08-13-2019, 01:12 AM Thread Starter
prplppleater's Avatar
I wasn't able to find any hard evidence as to whether the 24 valves still had a killer dowel pin or not so I decided to dig into my 98.5 to see what I would find. My dowel pin was protruding into the case by about 1/16", I'll post a pic of what it looked like. I tapped it back in and tabbed it, I don't know if it would have come all the way out but now I sleep well at night Hopefully this helps anyone else with a 24 valve who is on the fence about doing it. Truck only had 54k miles on it btw.
98.5 3500 Amethyst Quad Cab 24v
prplppleater is offline
The Following User Says Thank You to prplppleater For This Useful Post:
magnum12r (08-13-2019)
post #2 of 13 (permalink) Old 08-13-2019, 09:12 PM
magnum12r's Avatar
That's good to know, I have a 2000 24v and I'll have to check it out when I pull the timing cover soon (crank and cover seal leaking) my truck has 540k on it
Sent from my SM-N950U using Tapatalk
Clunk likes this.
magnum12r is offline
post #3 of 13 (permalink) Old 08-13-2019, 09:32 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
My 98 was backed out just a hair too, I tabbed it when I put the p7100 on.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #4 of 13 (permalink) Old 08-14-2019, 07:05 AM
Stormin08's Avatar
in most cases, this didnt hurt the 24V...rare exceptions, it has but not normal
02 Sport / 47re / 4" MBRP TBE / DAP 75hp sticks/ HX35W / GDP FUEL BOSS / DDRP02 / 3rd gen brakes / 4th gen steering / 2" Thuren / MC ARMS / 5100's /285/75/17
Stormin08 is offline
post #5 of 13 (permalink) Old 08-14-2019, 10:15 PM
they dont have them
smokestack69 is offline
post #6 of 13 (permalink) Old 08-14-2019, 10:30 PM
gun32gtr's Avatar
Originally Posted by smokestack69 View Post
they dont have them
would seem they do according the above photo
2003 f250 extracab
4.2 litre mwm sprint diesel soon to Be 12v 6bt p-pump,zf6 speed. Aiming for 350hp and 800 od nm
gun32gtr is online now
post #7 of 13 (permalink) Old 08-15-2019, 06:56 AM
Stormin08's Avatar
they have them, but they are not an issue in a 24v...
post #8 of 13 (permalink) Old 08-15-2019, 10:44 AM
They probably are not known to cause issues with 24v's cause vp44's arn't spinning 4k+. It's the same design as a 12v. That and perhaps the resonance created from turning a p-pump, who knows.
99 Ram 3500 SLT 4x4, 19.5's, P24v, ZF6-750, s362/475, 7x0.014, supporting mods.
marco610 is offline
post #9 of 13 (permalink) Old 08-15-2019, 10:47 AM
I think i remember reading that they tapered the pins in the 24v to prevent them from comming out
02' 2500 5.9L 24v ext cab sb 4x4
JeremyF is offline
post #10 of 13 (permalink) Old 08-15-2019, 12:03 PM
thansk for the info, I have a 24v, in a 2000 dodge. So I too thought you had to deal with it? I was going to do it for preventative care like you all. So, to confirm it is not an issue in the 24v? Thanks for any info.
Ripper6 is offline
post #11 of 13 (permalink) Old 08-15-2019, 08:51 PM
Stormin08's Avatar
could it be...sure. is it normally, no.
there was a redesign of the case i do believe. i dont recall, but i thought yhe case cover has numb that keeps it from extracting all the one.
post #12 of 13 (permalink) Old 08-15-2019, 10:36 PM
jakeandkatiesdad's Avatar
iTrader Score: 7 reviews
^^^^ Correct. The case has a stepped hole that won't allow the pin to fall into the gear case. In other words if the pin is 5/16" the hole into the case is only 1/4" for the last 1/4" or so allowing access to knock it out the other way if need be, but it can't come out into the case. Both my 99 engines had this newer style stepped hole but the internet claims KDP's in models as late as 2002. Only way to know for sure is to pull the cover.
99 Ram 3500 Dually, 4x4, extended cab, flatbed, Edge Comp, BHAF, 5" Diamond Eye TBE, 47RE w/ Revmax stage 3 & Transgo TFD, boost elbow, Raptor 100, Glow Shift boost gauge. ISSPRO pyro. and FP gauges.Had one of the 1% 53's. Swapped to Mexico block @ 96k.
jakeandkatiesdad is offline
