Fuel and cranking no start? - Dodge Cummins Diesel Forum
 2Likes
  • 1 Post By bigfish95971
post #1 of 11 (permalink) Old 07-14-2019, 06:22 PM Thread Starter
Recently I bought a 99 3500 for $700 knowing it didn't run I replaced the battery cables and bought new batteries the truck cranks fine and I have fuel from the lift pump to the vp44 and from the vp44 to the injectors but it won't start unless I spray ether in it and then it only runs for about 3 seconds off of the ether and ideas what it could be?
onasty69 is offline
post #2 of 11 (permalink) Old 07-14-2019, 06:40 PM
homeguy's Avatar
I bet itís one of the injector.
Sent from my iPhone using Tapatalk Pro
homeguy is offline
post #3 of 11 (permalink) Old 07-14-2019, 07:20 PM Thread Starter
Possibly but wouldn't bad injectors atleast run the truck but run very rough and smoke?
onasty69 is offline
post #4 of 11 (permalink) Old 07-14-2019, 09:08 PM
Clunk's Avatar
Is the Check Engine light On?
Have you had it checked for trouble codes?
I didn't have any trouble codes when mine did that, the injector pump was just wore smooth out. It couldn't open the injector nozzles....the pop pressure is 4500psi +or-250psi..
Installing a rebuilt injector pump put me back to instant starts.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is online now
post #5 of 11 (permalink) Old 07-14-2019, 09:36 PM Thread Starter
Sounds like that's more then likely the issue I just scanned it and it threw an injector pump code where did you get you pump from and how hard is it to install?
onasty69 is offline
post #6 of 11 (permalink) Old 07-15-2019, 12:45 AM
Available many places, don't pay over about $1100 + core. Where are you? Not too hard to replace, It takes 2-4 hours if your are decent mechanic and bleed it properly when finished. You do need to do it properly without shortcuts and will need a small steering wheel disc style puller, about 10-20 bucks. If you have any oil leaks in the vacuum pump or tappet cover gasket, do them at the same time, for only about 20 bucks each for new seal or gasket.
Bad VP44 codes are usually accurate.
Where are you located?
Clunk likes this.
bigfish95971 is offline
post #7 of 11 (permalink) Old 07-15-2019, 09:51 AM Thread Starter
In Toledo Ohio Northwest Ohio Southeast Michigan area
onasty69 is offline
post #8 of 11 (permalink) Old 07-15-2019, 09:52 AM Thread Starter
I'm a diesel tech at a Ford dealership so it shouldn't be within my skill limit
onasty69 is offline
post #9 of 11 (permalink) Old 07-15-2019, 08:08 PM
You should be good then. The injector lines come off in two groups of three. Do not bend them. Remove the rear lifting loop from head to get at #6. Be sure and put it back. Make sure you clock the key way on shaft to the same position as old one and it will match up fine. Finding TDC is not necessary if you do that. Make sure you replace all the blue clamps and in their original position or it will vibrate and brake injector lines.
I had mine rebuilt by a local shop Valley Injection in Woodland CA. Local shops must have a Bosch machine to do it correctly. Saved a couple of hundred that way.
Clunk likes this.
post #10 of 11 (permalink) Old 07-15-2019, 08:39 PM
Clunk's Avatar
What code did you get?
I used a small bendable mirror so I could see the injector pump shaft/pump gear keyway during assembly.
Clunk is online now
post #11 of 11 (permalink) Old 07-15-2019, 09:03 PM Thread Starter
P0216 code and roughly how much was it because it might be worth it to ship it out there if the price is right there's a couple of local shops around me that I'll have to call and see if they can do it
onasty69 is offline
