Need helping resolving boost issue. - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By 98whitelightnin
post #1 of 9 (permalink) Old 06-19-2019, 04:43 PM Thread Starter
I have a 01 with 265 air dog, 120 injectors, hot rod vp, edge comp stack with smarty. I installed a modified hx-35 62/67. I adjusted wastegate and installed adjustable boost elbow and still barely getting 40 psi at WOT. I even installed an old boost fooler to see if that would change anything and nothing. I want to try to get 45-50 depending on efficiency but donít know what Iím missing. If anyone can help itíll be greatly appreciated!
Jd24v is offline
post #2 of 9 (permalink) Old 06-19-2019, 08:32 PM
Clunk's Avatar
I didn't think you could run any modules with a hot rod VP.
Stack a smarty on a Comp?
Way outta my league pal.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
post #3 of 9 (permalink) Old 06-19-2019, 10:20 PM Thread Starter
Same module. I have the stealth cover on it as well. Itís pretty common stack from back in the day. It apparently lowers numbers but low and high end are strong. Very fun to drive lol I could remove the smarty but I will once I get hot unlock from edge.
Jd24v is offline
post #4 of 9 (permalink) Old 06-20-2019, 07:00 AM
Stormin08's Avatar
the hotrod vp doesnt like boxes that add timing...as it is already advanced internally.
the smarty makes the down low driving very responsive due to its fueling map...it is all go, at very low boost and input.
ssve your money of the hot unlock and look into a better tuning device. currently, there is one dominant choice.
02 Sport / 47re / 4" MBRP TBE / DAP 75hp sticks/ HX35W / GDP FUEL BOSS / DDRP02 / 3rd gen brakes / 4th gen steering / 2" Thuren / MC ARMS / 5100's /285/75/17
Stormin08 is offline
post #5 of 9 (permalink) Old 06-20-2019, 07:01 AM Thread Starter
Ok. Which one do you suggest?
Jd24v is offline
post #6 of 9 (permalink) Old 06-20-2019, 07:15 AM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
Quadzilla adrenaline is the best for vp trucks.
Jd24v likes this.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is online now
post #7 of 9 (permalink) Old 06-20-2019, 09:23 AM Thread Starter
Iíll look into doing it soon! I just want to resolve my boost issue prior to selling the edge and smarty
Jd24v is offline
post #8 of 9 (permalink) Old 06-20-2019, 11:20 PM
Stormin08's Avatar
talk to this guy....
@jkidd
he can set you up with a Quad V2, that is currently the strongest, most end user tuneable there is right now.
post #9 of 9 (permalink) Old 06-21-2019, 06:45 AM Thread Starter
Finally got it right... found broken wire on edge harness. But I am for sure going to sell smarty and edge and get the adrenaline! Thanks for yíalls input!
Jd24v is offline
