Please excuse the newbie - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By 2wd5point9
post #1 of 10 (permalink) Old 06-12-2019, 05:59 AM Thread Starter
2wd5point9's Avatar
Finally switched over to the dark side. Coming from a powerstroke. I recently purchased a ming 01 with only 100k miles. I like knowing the ins and out of everything. I'll attach a photo of something I've been wondering. What's the void sticker for?
Sent from my SM-N950U using Tapatalk
2wd5point9 is offline
post #2 of 10 (permalink) Old 06-12-2019, 07:01 AM
Stormin08's Avatar
your VP pump has been replaced...
one mod for these trucks is a WIRETAP fueling box...if that cover is ever removed, it lets the warranter know you tampered with it.
02 Sport / 47re / 4" MBRP TBE / DAP 75hp sticks/ HX35W / GDP FUEL BOSS / DDRP02 / 3rd gen brakes / 4th gen steering / 2" Thuren / MC ARMS / 5100's /285/75/17
Stormin08 is offline
post #3 of 10 (permalink) Old 06-12-2019, 07:02 AM Thread Starter
2wd5point9's Avatar
That's crazy the original owner didnt mention it
post #4 of 10 (permalink) Old 06-12-2019, 07:52 AM Thread Starter
2wd5point9's Avatar
So I guess your saying a factory VP doesnt have the void sticker?
post #5 of 10 (permalink) Old 06-12-2019, 06:47 PM
Clunk's Avatar
Seems like mine said "Void if Removed" and it was across the big plug in....main plug to the original injector pump.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
post #6 of 10 (permalink) Old 06-12-2019, 07:41 PM Thread Starter
2wd5point9's Avatar
So because it says "Void" only are you suggesting it's a new vp as well?
post #7 of 10 (permalink) Old 06-12-2019, 09:32 PM
Stormin08's Avatar
it could be a factory sticker....but i have never seen that done by the factory. Only on aftermarket electronics.
what lift pump does it have, the fuel line says something has been changed.
the stock VP was notorious for dieing from overheated solider loosing connection and shorting out.
the bad is, if it is a stocker and you daily drive it short spurts and shut down...the vp gets heat soaked and tjat kills thesolider on the boards.
replacements rarely have that issue due to better solider being used.
post #8 of 10 (permalink) Old 06-12-2019, 09:33 PM Thread Starter
2wd5point9's Avatar
I just put a fass 95gph on it last weekend
post #9 of 10 (permalink) Old 06-12-2019, 09:38 PM
Stormin08's Avatar
1 recommendation...look into a relocation kit, and move it to the frame.
post #10 of 10 (permalink) Old 06-13-2019, 04:56 AM Thread Starter
2wd5point9's Avatar
It is.
Stormin08 likes this.
