Hypertech killed my cummins - Dodge Cummins Diesel Forum
LinkBack Thread Tools
Old 06-08-2019, 02:32 PM Thread Starter
Hi, i tried putting in a tune from my hypertech and it had error 65 and now i cant get it back to stock settings and i cant get my truck to start.
i tried calling hypertech but they basiclly told me that my ecu was fried
anyone heard or experienced this?
sincerely
nonisossose is offline
Old 06-08-2019, 08:40 PM
Stormin08's Avatar
it happens, especially with the age of these trucks.
02 Sport / 47re / 4" MBRP TBE / DAP 75hp sticks/ HX35W / GDP FUEL BOSS / DDRP02 / 3rd gen brakes / 4th gen steering / 2" Thuren / MC ARMS / 5100's /285/75/17
Stormin08 is offline
Old 06-09-2019, 06:40 PM
NCC74656's Avatar
i would never try and flash an ecu as old as ours when we dont have any support on the matter. our ECM's arnt even made anymore, even cummins cant sell us a new one... any time you flash you want to have some control over it and to my knowledge no one has managed to dump the factory ecm programming so there is no way for anyone to unbrick them in their garage. if we had the raw code then perhaps you could solder to data viers on the board and force a sector write back to the chips - ive done this on routers, play stations, dream casts and so on but in every case we had the source code.
your best bet is to just send the ecm out to a rebuild company and either buy a new one with trade in or get it 'rebuilt'. you may be able to find a used one at a salvage yard some where. i managed to find my new ecm for about 100 bucks but a safe bet is around 1K.
99 QC,LB. full billet trans, fass 150, iquad, 37", 407Lbs grill guard, DAP VP44, Thuren coils, Thuren king shocks, DoR control arms and trackbar, 16K lbs winch, retro solutions HID. Redhead gear box, compound turbo, DAP 125's, stroker W/HO pistons, 4.10/Elocker
NCC74656 is offline
Old 06-13-2019, 04:26 AM Thread Starter
well this is a bit funny, i removed the battery cables and had it sit for a couple of nights and this morning i put the cables back in, turned the ignition on and plugged the programmer back in, it automaticlly rewrote it back to factory settings successfully and the truck now starts.
it idles great but when i drive it it starts to sputter just like it doesnt get fuel the way it suppose to. but thats just a guess.
sincerely
Old 06-13-2019, 06:57 AM
Stormin08's Avatar
you may try
@BobWagner
he mayhave some insight or options...bob is the state side guru of smarty.
The Following User Says Thank You to Stormin08 For This Useful Post:
Bob Wagner (06-13-2019)
Old 06-13-2019, 04:34 PM
Bob Wagner's Avatar
what year truck? did you buy the hypertech used? It could have rewritten the wrong calibration back into your ecm.
Smarty Know it all.
Bob Wagner is offline
Old 06-13-2019, 04:39 PM Thread Starter
its an 99 cummins.
but i got it sorted out, somehow i blw a fuse for the fass lifting pump.
do i have the guts to try plugging in the hypertech and go for stage 3 or was this my last chance given before it rapes and kills my ECU?
sincerely
Old 06-13-2019, 04:57 PM
At this point, hopefully the vp44 isnt damaged from running with no lift pump. I would confirm wiring integrity for fass lift pump to find possible short. Fuses do not blow on their own or go bad. I would send your programmer out to be repaired or tested before trying to use it again.
02' 2500 5.9L 24v ext cab sb 4x4
JeremyF is offline
Old 06-13-2019, 07:32 PM
Stormin08's Avatar
i still flash mine with a superchips from 02...so far, no issues.
if it was in deed a fuse, i personally am not scared to flash.
Old 06-14-2019, 02:20 AM Thread Starter
i cant think vp44 would be bad, i only ran it for like 2 minutes and most of it was idle. truck runs fine now atleast. but i do am curious about the stage 3 on the hypertech..
sincerely
Old 06-16-2019, 09:48 PM
akhr's Avatar
Consider getting a quadzilla. They are very capable tuners and don’t flash your ecu.
akhr is offline
