Which Transmission - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By cumminsbro2013
post #1 of 8 (permalink) Old 05-21-2019, 02:48 PM Thread Starter
Which Transmission
Rebuild my current 47re and get a better torque converter for hauling, or rebuild my Allison 1000 5 speed, and put it in my 1999 24v 2500? What is your reasoning behind your answer, what all will I need minus new flex plate and adapter for the Allison to work?
cumminsbro2013 is offline
post #2 of 8 (permalink) Old 05-21-2019, 04:42 PM
Killjoy's Avatar
I say stick with the 47re.
As good as the allison is, at some point its gonna need to be rebuilt too. Which is gonna sink you into a bigger hole after you get done sourcing a stand alone tcu, tcase, driveshafts made, etc. I have a lb7/allison in the yard so I can say with experience it's a wonderful unit until you push it past stock power levers. At that point shifts suffer, and you can chuck it into limp mode over and over until it finally dies.
47re however, is already there, imo building that would be a better investment than the allison at this point.
Just my $.02
2002 ram 2500 quad cab shortbed ST. Red, 4x4, nv4500 swap 24v, 66mm silver bullet, 100hp injectors , fass titanium 150, 4" exhaust, guages. 190k miles.
Killjoy is offline
post #3 of 8 (permalink) Old 05-21-2019, 05:39 PM
Unless your wanting to pay for all the swap parts listed above for one extra forward gear, I would stick with the 47 as well.
2001 QCSB 2500 maxd 215ppump,7x.014s,S300/S400 Hamilton188/[email protected],street/strip project.
2012 CCSB 3500 Leveled,Black Maxx,Flo pro
DJRobinson is offline
post #4 of 8 (permalink) Old 05-21-2019, 05:43 PM Thread Starter
Just my $.02
any list of upgrades I should? This will be a workhorse hauling round bales of hay and cattle in a trailer, and the occasional male stomping on it. I know triple disc TC do you recommend one? I know this is about to get expensive which is what I was trying to avoid but I don’t think that’s possible with this transmission and what I’m needing it to do.
post #5 of 8 (permalink) Old 05-21-2019, 05:45 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
Give the folks at Goerend a call and tell them your plans, they fixed me up nicely.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
The Following User Says Thank You to 98whitelightnin For This Useful Post:
cumminsbro2013 (05-22-2019)
post #6 of 8 (permalink) Old 05-21-2019, 06:39 PM Thread Starter
Gave them a call, will get a quote tomorrow. Thanks for the help!
98whitelightnin likes this.
post #7 of 8 (permalink) Old 05-22-2019, 12:43 AM
Killjoy's Avatar
Just my $.02
I had good luck with a suncoast triple.
While it's out of the truck...
A good VB, extra clutches, billet band anchor, strut, pin, servos, wider band, all that stuff should get you a decent setup. I would do billet shafts if you're gonna throw some coin at it to make it last. Last thing you want is to snap an input shaft....
Killjoy is offline
The Following User Says Thank You to Killjoy For This Useful Post:
post #8 of 8 (permalink) Old 05-22-2019, 11:58 PM
chadmac's Avatar
I agree...I did the same and Goerend fixed me up on parts and guidance on a high hp capable rebuild. It has been nothing but solid behind big power.
02 2500 4X4, reg cab shorty, 3.55, Smarty/TST, 75 over 62, 150 inj, 5" exh, 12" lift on 20" 34's, Goerend billet triple disc auto, Yukon hub/bearing kit
chadmac is offline
Similar Threads
2010-2012 6.7L Service Data & Part #s shanepx2 4th Gen Powertrain 192 07-21-2018 06:06 AM
Complete safe transmission fluid change method ? bluedoor 94-98 Powertrain 1 05-04-2018 09:45 PM
47RE Gurus, I need input. davedriveschevys 98.5-02 Powertrain 7 02-20-2015 03:28 PM
2001 2500: Another bad automatic transmission defdes 911 Urgent Situations 5 01-31-2015 07:41 PM
Mystery Transmission Chrismelto 89-93 Powertrain 8 01-10-2015 11:57 AM
